Hi I am just wondering if there is any way of fitting a E30 hardtop without the locating pins. I do have the locating pins but one is faulty? Any help would be much appreciated
Need advice on fitting e30 hardtop
bhaza
Hi I think I understood that just to clarify. Are you saying remove the locating pin from the hardtop and then remove the receiving bracket and remove the plastic insert in the bracket and use a bolt instead of locating pin?
Topblag
I don't think this is how I do it. I fit the pins to the car, then place the hardtop onto the pins, then put the nut onto the pins and secure.
It may be a matter of language but your approach seems more complex than mine.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
bhaza
Yes one pin just does not lock in at all so the bolt idea is pretty good thanks
Please help with my steering wheel issue as well its anuva thread in this chat
thanks
thanks
