lightened flywheel
jonny323i
Post Mon Jun 04, 2012 7:22 pm
What's involved in lightening a flywheel is it as straight for ward as just machining of metal please could someone explain it clearly
Touring for life
maggspower
Turbo Farmer Tractor Driver
Post Mon Jun 04, 2012 9:07 pm
Hi there, the flywheel will need machining down to flush with the ring gear on the engine side, then how ever much you want, or feel comfortable scolloping it out. Next it thould be balanced, when new BMW balanced the bottom end to within an inch of its life, and is so important to do so again, the more material that is removed the more potential there is for the fly wheel to be inbalanced.
HTH
Pmed
driftwood
Post Tue Jun 05, 2012 1:34 am
How much weight should be removed? I know it's dependant on application but is there a guide?
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Jun 05, 2012 6:02 am
BigBavarian
Post Tue Jun 05, 2012 7:04 am
I do a range of light weight flywheels, new chromoly billet steel, dynamically balanced and for all engien and clutch applications. An M20 flywheel for example weighs 8.5kgs standard, mine weigh 4.5 kgs for standard clutches, 3.5 for race paddle clutches. PM me if interested.
Richard
