I've read most if not all the threads on h2.7 but still can't find my answer,may be this question will help explain.i have a 325 engine in good condition but Id like to make it a2.7.the build is well documented on here with different variations,birds still do hartge conversion.although a lot of money this appeals mainly becuase the quality parts warranty ect,but with an engine pushing 20 years would said company be a waste of time?
The conversions they did all seem to be when these engines were new.
Hartge
Grrrmachine
- E30 Zone Wiki / Team Member
Hartge's conversions weren't just about displacement; there was a specific six-branch manifold, a differently-profiled cam and a tuned ECU to make best use of it all.
You can achieve the same effect yourself with aftermarket components (BTB manifold, dyno tuning, and a cam with the specs outlined in the Wiki).
To be honest, the Wiki really needs the help of a Hartge expert, but no-one's volunteered
guss
Yes I understand this but 1 costs 6k and the other 3k is there difference or are you just paying for a senior technician with a hartge logo ,after all theirs no forced induction it's a easy engine to work with..... I here
Grrrmachine
oh RIGHT. Well, in terms of quality of work it's debatable. Hartge as a firm have a long history, but the job is only as good as the technician and there's no guarantee that your 6k Hartge conversion will be done by the same guy that did them 20 years ago. You could arguably get the same quality job from someone much cheaper. Also, people who own genuine Hartge's have commented at the bodgery observed to make the big engines fit; gearbox tunnels clouted wider with sledgehammers....
But if the car receives a genuine Hartge conversion, it will retain some sort of value into the future that a backstreet conversion won't. Whether that will be worth the 3k difference in price though, is for the buyer to decide should you ever sell the car.
guss
thanks might go for the 3k with supercharger then
The 6k Hartge conversion gives you a reliable proven combo that works with excellent aftersales backup. The 3k Fred in a shed option gives you a 3k saving .
guss
i think if it was done by hartge (birds) people would for ever be saying its not left hand drive ect which wouldn't bother me at all as everything would be upgraded suspension diff rebuild or new which evers cheapest. could take a while this
they wouldn't be saying that thought. LHD has nothing to do with it.
if the rest of the car is a shed people will wonder why someone would spend 6 large on an engine when the rest isn't up to it
polsta
if you were to do a birds conversion on an old engine with new parts on the head etc, you should probably get a bottom end re build done 1st ?
be interesting to read what other options there are for a 2.5i lump to increase the power a bit without going mad, not cowboy style but without spending 3 bags or full re builds ?
A H27 conversion includes new pistons, crank and obviously new rings and bearings so the bottom end would be rebuilt.polsta wrote:if you were to do a birds conversion on an old engine with new parts on the head etc, you should probably get a bottom end re build done 1st ?
The H26 conversion was essentially a cam, head skim to raise compression ratio and a reprogrammed ECU to give circa 190bhp.polsta wrote:be interesting to read what other options there are for a 2.5i lump to increase the power a bit without going mad, not cowboy style but without spending 3 bags or full re builds ?
jonny323i
How do you know they still do the m20 conversion
Touring for life
polsta
bss325i wrote:The H26 conversion was essentially a cam, head skim to raise compression ratio and a reprogrammed ECU to give circa 190bhp.polsta wrote:be interesting to read what other options there are for a 2.5i lump to increase the power a bit without going mad, not cowboy style but without spending 3 bags or full re builds ?
so on a standard m20, could you do similar to get 190bhp without having to get new manifold etc and a 3k bill ?
