NEED HELP ON THIS RUST ISSUE thanks !
Duke137
Post Sun Jun 03, 2012 11:45 pm
Battery tray is a fave and boot carpets out is relatively easy place to start. Good luck mate, we always like to see them getting saved!
craggsyE30
Post Sun Jun 03, 2012 11:48 pm
haha thanks im praying its all good and nothing is shity on it ill get some pics of each part i looked at the battery tray had a little rust but not falling to pieces. cheers lads will see whats going to happen tomoz haha
craggsyE30
Post Sun Jun 03, 2012 11:52 pm
that link is very helpful i can see what to look for and check it off when im done haha
Duke137
Post Sun Jun 03, 2012 11:54 pm
craggsyE30 wrote:that link is very helpful i can see what to look for and check it off when im done haha
Everything is in the wiki mate, it is brilliant.
You will be able to rebuild the thing using the wiki, don't bother with a Haynes book of lies! 8)
craggsyE30
Post Sun Jun 03, 2012 11:56 pm
yh should be a fun day tomorrow seeing what needs doing. does welding cost a but of money to do or is it something you either spend more get more spend less get less
Duke137
Post Mon Jun 04, 2012 12:06 am
Well welding is always price on application really mate, depends what is involved. Some is easy, some is tricky to access and fabricate.
I think you should look round the car, see what you are up against and post some pics?
I bought myself a mig and gas set up and had a go myself as a total novice. My worst enemy is having the time to do it, it is time consuming as hell because that bulkhead repair involved removing EVERYTHING, engine, dashboard, the WHOLE Wiring loom :eek:
Took about 2 weeks to get it even close to cutting the rot out lol
craggsyE30
Post Mon Jun 04, 2012 12:12 am
wow long time then, so plan of attack:
check all thats in tha wiki basically and get pictures of each one even if its not rotten or if it is.
decide to tackle it or not and also find someone who can do the welding.
Duke137
Post Mon Jun 04, 2012 12:15 am
craggsyE30 wrote:wow long time then, so plan of attack:
craggsyE30
Post Mon Jun 04, 2012 12:23 am
cheers man help loads there now i know what im looking at will have pics in morning
craggsyE30
Post Mon Jun 04, 2012 9:55 am
right found this when looking at the rear arches hmm looks like the left side has been either patched up before and rusted again or the real reason is its a fucking cowboy job:
this is the left side cowboy repair
this is the right side which hasnt been touched. id say its much better off being left than a cowboy touching it:
craggsyE30
Post Mon Jun 04, 2012 9:57 am
right time to go see whats in the boot eh
craggsyE30
Post Mon Jun 04, 2012 10:25 am
found this in the boot looks like sheets of some random shit wich i thought straight away its covering rust but im wrong form what i can see it isnt rusted ? why is this on it
Zerotonine
Post Mon Jun 04, 2012 10:33 am
Looks like someone has tried to line it with soundproofing stuff, so they can have a sub in the back with no rattles. But I could be wrong. Can't remember what it is called though.
Finally promoted to Regular! Only took 7 years...
craggsyE30
Post Mon Jun 04, 2012 10:34 am
i thouhgt the same about it being a sound proofing thing but didnt know what for
craggsyE30
Post Mon Jun 04, 2012 11:54 am
so guys im quite happy am with the rust issue since the boot looks ok enough the main thing i want sorting is that turret onece thats done ill be at piece its kinda if that went id be fucked
aimlessrock
Post Mon Jun 04, 2012 4:31 pm
Craggsy, mine was like a flintstone car when i purchased my resto, ...rot is sadly to be expected.
I would avoid plating and spend a little now to get the job done properly.
I have a mate of mine who is a welder for a living if you need a quote, he is based in both Manchester but his work is amazing.
PM me if you need his details
E30 320i Convertible (1989)
190 Mercedes (1988)
craggsyE30
Post Mon Jun 04, 2012 6:18 pm
ah right thats a bit far to go for me mate but thanks anyway appreciate it though, on the other hand if i sent him a photo of what im wanting doing whould he be able to quote me ? i can get a detailed pic of where the rust starts/ends thanks
G-Bear
Post Mon Jun 04, 2012 7:12 pm
This is a bit off topic to the rust around your suspension turret, but the link below shows a good example of the work you may have ahead of you re your rear arches...
http://www.e30zone.net/modules.php?name ... c&t=178119
There are plenty more useful threads on this site, plus as already mentioned, wiki is a great resource.
The carpets are up on my iS at the moment on a rot hunt, it makes for a noisy drive.
I only had a little poke at this, so am sure it'll get bigger as I get the sound deadening up and have a proper poke, just didn't want any bigger a hole for now as I'm still using it most days currently.
The other side had just been plated from underneath, but as you can see the rust issue hasn't been sorted..
My rear arches look suspicious too....
The rear valance on mine has a lot of rust too so I've certainly got my work cut out.
I'm pretty much a novice too. I intend on finding a place where I can work on it soon and get cracking at it. If I fail then its getting weighed in but at least I would have tried to save it. :D
I hope I haven't hijacked your thread mate. Just thought I'd put a few pics and a link up as encouragement, its hard to keep positive when its all new..
Good luck chap..
G-Bear
Post Mon Jun 04, 2012 7:17 pm
craggsyE30 wrote:found this in the boot looks like sheets of some random shit wich i thought straight away its covering rust but im wrong form what i can see it isnt rusted ? why is this on it
That 'sound proofing'.. looks more like what roofers use..
rich318i
Post Mon Jun 04, 2012 7:21 pm
its basicly the same stuff
craggsyE30
Post Mon Jun 04, 2012 7:39 pm
g - bear hijack as much as you want mate the more i know other people have gone through it i feel better. as for the rust issue iv got a year and a bit to sort it all out its taxed/mot'd so i can get a family member insured on it to move the car about im going to get stuck into it its basically my first car that iv got with my own hard money/ that i can drive and want to make it look awesome.
as for the rust its going to get a fucking bolicking not going to much of it left when im done. its a good car one of my favourites so will keep at it. got a mechanic looking at the turret soon and going to get two new wings . ive just had the werser side off and it aint bad ill have a go at this.
craggsyE30
Post Mon Jun 04, 2012 8:01 pm
right heres what i have fund when i took the wing off
and i checked the rear nubmer plate and lights no rust where there is normally and im guessing this sound proofing has actually saved it abit
and the sunroof hasnt seeped water from what i can see
G-Bear
Post Mon Jun 04, 2012 8:05 pm
Good spirit craggsy :thumb: ... Looks like you're not hanging about..
craggsyE30
Post Mon Jun 04, 2012 8:20 pm
yh man im not leaving it to get rusty its going to be geting the wings and turret sorted straight away since iv been payed. once the car atually lucks a bit better ill feel better and start sorting the rest out
Duke137
Post Mon Jun 04, 2012 8:38 pm
Get some quotes first mate before you start spending loads of money.
Clean 2 door shells are getting hard to come by so I think most are in need of some work. Rot free 2 doors 'on the cheap' just don't exist unless you get lucky :(
craggsyE30
Post Mon Jun 04, 2012 8:43 pm
haha i can pritty much see why i never see any e30's driving about but tbh as long as i can get that turret sorted ill feel alot better if its not loads ill be happy pluse the mechanic can have a look over it as in engine wise etc
Duke137
Post Mon Jun 04, 2012 8:46 pm
craggsyE30 wrote:haha i can pritty much see why i never see any e30's driving about but tbh as long as i can get that turret sorted ill feel alot better if its not loads ill be happy pluse the mechanic can have a look over it as in engine wise etc
You know you can use the wiki to find out what to look for :)
Chucking oil and filters in these every 6 months does no harm at all, I would hold back on spending on the engine though until you know how much the bodywork will cost you. Top tip that mate :thumb:
craggsyE30
Post Mon Jun 04, 2012 8:52 pm
oh yeah i mean mechanically wise its sound atm apart the exhaust is blowing but that's nothing atm so main priority is to get the body work mainly rust sorted so its road worth which apparently it is but i highly doubt the next mot will say it is unless i fix that hole and looks the shit
Duke137
Post Mon Jun 04, 2012 8:55 pm
How some E30's get an MOT is beyond belief given the state of some of them!
rich318i
Post Mon Jun 04, 2012 8:57 pm
check under your roof aswell via the sunroof on a tilt with a good torch and pray!!! after seeing my mates it made me check mine and was good so got a aerosol can of waxoyl and used the whole can just on the roof. DO THE SAME!!!!
craggsyE30
haha mate when he showed me minors where on mine on its last mot now that i think of it how did it only had a oil leak, rust wings and exaust blowing on it was beyond me know doubt its a dodgy mot but wtf
craggsyE30
Post Mon Jun 04, 2012 9:00 pm
so guys here is the current pic for everthing im on facebook etc loving this site had to be done
rich318i
Post Mon Jun 04, 2012 9:02 pm
Duke137 wrote:How some E30's get an MOT is beyond belief given the state of some of them!
the ash tray was put in E30's for the MOT man's £20
G-Bear
Post Mon Jun 04, 2012 9:04 pm
Duke137's right. Even if you're prepared to spend m
Duke137
Post Mon Jun 04, 2012 9:05 pm
You're in the right place mate, you can get all the help you need off this site but don't expect anyone to pay the welding bill lol, we are all tight coonts :)
Bit of encouragement is good but don't blame us when your girlfriend has had enough and you spent your weekend beer money on rusty scrap :D
