Electrical Problem.......
Rich25i
Post Thu Dec 01, 2005 12:10 pm
Hello peeps can anyone help? Every so often when i brake and turn the indicator on to turn right the check control panel lights up and informs me a brake light is out. The brake lights are fine and this goes away once you turn the ignition off then on again untill the next right turn. Any ideas?
Martinaston
Post Thu Dec 01, 2005 12:17 pm
dodgy earth on the back lights ?
There is NO nucleus.
kam-325i
Post Thu Dec 01, 2005 12:19 pm
I had exactly the same problem on old 320i, it turned out to be the additional wiring/buzzer added in the rear for the factory towbar.
Might be worth just removing the earth for each of the rear lights and just brushing them up a bit.
Rich25i
Post Thu Dec 01, 2005 12:32 pm
Cheers had a feeling about earths. i will let you know if that fixes it
