Alarm system
sniper_slb
Post Thu May 31, 2012 4:13 pm
hi people,
My e30 318 M40, has an alarm that was an extra accessory at the time.
follow the link scheme alarm that have: http://bmwfans.info/parts/catalog/E30/4 ... _system-3/
but the problem is this, i not have the codes and I wonder, how I can program new codes? if I send an email will be bmw they can provide me the alarm code? or is it better to forget?
Post Thu May 31, 2012 6:30 pm
What sort of 'codes' are we talking about? Ones that are entered by a key pad, or ones that are pre programmed into a remote control fob?
The only keypad entered alarm code I've ever come across on an E30 is the one associated with the twelve button OBC, next to the radio, or the magnetic key thing sometimes found on cabs..
sniper_slb
Post Thu May 31, 2012 6:39 pm
Brianmoooore wrote:What sort of 'codes' are we talking about? Ones that are entered by a key pad, or ones that are pre programmed into a remote control fob?
I'm talking about the codes to program a remote control that turns on / off the alarm and open / close the car doors. in this case alarm speak also serves to close the opening windows and tector if it is electric
Post Thu May 31, 2012 6:47 pm
Pre programmed into a remote fob?
sniper_slb
Post Thu May 31, 2012 6:48 pm
is the code I need to program the command that this marked the 5 in the scheme
sniper_slb
Post Thu May 31, 2012 6:49 pm
Brianmoooore wrote:Pre programmed into a remote fob?
Yes!
Post Thu May 31, 2012 7:07 pm
Alarms of this age are usually coded by cutting tracks and/or bridging pads on the circuit board around the encoding chip.
You need to open up the alarm receiver, note the type number of the decoder chip, and note the cuts/bridges in the PCB tracks around it. Next, enter the decoder chip into 'google' and you should be able to find the spec. sheets for both this chip and the matching encoder chip that will be in the remote fob. By reference first to the decoder spec. sheet, you should be able to work out the code that is used on this particular alarm, and then, by cross referencing this to the encoder spec. you should be able to work out the required coding for the encoder in the fob.
Next to have to find a remote with the correct encoder chip, and modify the existing coding around this chip to what is needed.
I did all this once, and can report that it's a long winded process.
Probably a lot easier to rip out the old alarm and replace it with a modern unit from the likes of Rightclick, and marry this to your existing central locking and total closure system, which will give you two nice new shiny remote fobs, and the option to buy more.
sniper_slb
Post Thu May 31, 2012 7:17 pm
Thank you,
I try to open the receiver of the alarm and try to see what I can do
