Hi, I realise this is probably one of those 'how long is a piece of string questions' but I am probably selling my e30 and it has the dreaded rot on one of the drain holes in the sunroof tray. i was wandering how much less people would expect to pay for a 1.8is with this problem. Its probably going to a friend of mine who I have made clear of the proceedure involved in fixing it. Just trying to reach a reasonable price.
If anybody has had the job done professionally that would also help me figure it out.
Thanks, Matt.
sunroof tray rot, whats the cost?
polsta
1st thing id do...is get some fertain, and squirt it right down there, a couple of days later do it again, maybe also with a small funnel with some plastic tubing attached to the end put down the hole, fertan the f**k out of it, at least that will cure the rust and prevent it getting worse
Duke137
Fook sake Polsta you really have a hard on for fertan....
Roof rot is terminal usually
polsta
so what...not mention it ?
its good stuff and would be a good help to get in areas like that, like you say roof rot terminal, at least that can help keep it at bay and slow it right down or possibly even halt it
Barx325i
genolite & red oxide FTW
some sound advice here from the usual bodgit crew
hairy mary/red oxide and rust treatment ?
I take it as it's the front sunroof drain as thats the one's that are visible?
so long as it's Local rot and it hasn't spread far from the tube area it shouldn't be a massive job for someone handy with a MIG,
the hardest part is removing the headlining to get to it properly (i think it's covered in the Wiki)
if not..front screen /visors/trim out and lower the front part down to get decent access
Barx325i
Banter mate, I don't have a sunroofe30topless wrote:red oxide and rust treatment ?
Tom_Maverick
No sunroof? You need some Fertan...Barx325i wrote:Banter mate, I don't have a sunroofe30topless wrote:red oxide and rust treatment ?
zimmermatt
Hi, yeh ive read the wiki about removing/replacing the tray. What i need to know is how much people think this would effect the price of the vehicle by as i dont want to do it. and the only fix would be a new tray as the existing drain corner is non existent and u can poke the roof lining
