Hello can i have prices for the following please:-
Car is 1988 M3
16 11 1 177 925 connection pipe 1 required
16 11 1 744 369 Rubber O ring D=58,8X4,2 2 required
16 11 1 177 345 Heat resistant plate 1 required
16 11 1 177 347 Bracket right 1 required
16 11 1 177 346 Bracket left 1 required
16 12 1 177 553 Hose 14X20X1340 1 required
13 32 1 284 682 Bracket 1 required
13 32 1 713 062 Bracket 1 required
63 12 1 364 431 Cable clamp 6mm 4 required
33 31 1 129 676 Inner Hex bolt 4 required
51 14 1 823 900 Blind plug 11mm 4 required
51 71 1 904 603 Blind plug 6mm 4 required
51 71 1 911 299 Blind plug 6.9mm 4 required
51 71 1 884 759 Gasket 1 required
07 11 9 911 611 M8x30 bolt 2 required
07 12 9 922 770 M8 lock nut 2 required
07 11 9 933 096 Spring washer 2 required
32 31 1 156 226 Gasket 1 required
32 31 1 122 041 M8x38 bolt 4 required
07 12 9 922 716 M8 self locking hex nut 12 required
32 31 1 156 227 Cup 1 required
34 41 9 064 267 handbrake repair spring set 1 required
34 41 1 100 640 Pin 2 required
34 32 1 158 467 Brake pipe bracket 1 required
34 30 1 161 567 Brake pipe bracket 4 required
35 31 1 153 896 clutch pedal cap 1 required
35 31 1 152 237 Clutch stop buffer 1 required
61 13 1 373 669 Push button 1 required
16 13 1 176 749 Bracket 1 required
16 13 1 179 779 Protection plate 1 required
Will ring you when i get prices as allways
Thanks again
Leigh
Parts prices please
bigbird76
Cotswoldbmw
Dear LEIGH.
Thank you for your enquiry, the price for the parts required will be £205.09.
All prices quoted are for Genuine BMW Parts and include a discount for enquiring on line, VAT and no postage charge to a mainland UK address. If you need a price breakdown please send me your email address. The part ending in 267/682 is no longer available from bmw and some of the other parts will have to come from Germany. Thanks.
Give us a call to place an order on 01242 257999 and please quote reference number 50716
Regards
Paul
Paul Webb
Parts Advisor
Cotswold Cheltenham
Main Telephone Number: 01242 257999
Fax Number: 01242 257150
E-mail: partscheltenham@cotswoldgroup.com
Website: www.cotswoldgroup.com
Regards
Paul
Paul Webb
Parts Advisor
Cotswold Cheltenham
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
