Thought I'd post the following looking for some advice and parts to get my soft top going again....Adi, please read on!
My roof has worked since I've had the car, but last summer, while I was raising it, there was an almighty bang and things stopped working.
I had to disconnect the drive motors to get the roof back up, and on my initial inspection, I found the main raising arm bent through about 45 degrees. I purchased the bits I thought were necessary from the dealers and had a good look over the weekend.
I found this...
This pic shows everthing as it should be.
The next one shows the postion of the roof (being raised manually) before it will not go any further.
A peak inside the storage compartment shows that the oval shaped hood raising plate slips off the one underneath it. When the roof is being rainsed this has to slide back over the one at the bottom, but jams against the round silver disc.
The loud bang must have been due to the plate hitting the silver disc. The next two pics show the damage...
The silver disc circled in red is what the top plate mechanism catches on.
Can anyone tell me how to tighten the silver disc so that it doesn't stick up so much - need a special 2 pin type tool for the holes. Also I require the oval shaped top plate (the one with the all the damage to it).
Once these are replaced, I can reconnect the motors and things should work again.
Many thanks in advance!
