Don't know if this has been posted before, my manifold gasket was blowing so after a bit of reasearch decided to try locktite 5920 copper silicone, and i must say it has done the trick up to now. 500 miles and it's still holding up and got rid of that awful ticking noise.
I know it's not as good as replacing the gasket but it's far cheaper. Will let you know how long it lasts.
Cheers Andrew
Manifold gasket blowing
atlantis
E30 325i cabby
E39 525i sport in Atlantis blue
mcbonio
Did you remove the manifold before applying it? Or just loosened it off a bit?
atlantis
Neither just applied it to the hole.
E30 325i cabby
