Basically I am on the search for a Z3 LSD for my m30 conversion and I'm new to the z3's and was just wondering is it only the Z3M that had the factory fitted LSD.
P.S I hope this is the correct place for this topic, admin move it if necessary.
What Z3 has the appropriate diff for a e30?
Black_Op_88
kerrie
Z3 2.8 has a torsen diff as standard, the plate LSD from E28/E30 is best in my opinion. Google search torsend lsd for some info.
M60 Touring and Sport
Black_Op_88
ta very much palkerrie wrote:Z3 2.8 has a torsen diff as standard, the plate LSD from E28/E30 is best in my opinion. Google search torsend lsd for some info.
don't write off the 2.8 LSD. They will get a Z3 VERY sideways just like God intended and lsd to do. Its all a bit quick with them as Z3's are snappy. I'm sure one in an e30 will still send you the direction of the hedges
leeparkes
What ratio are they on the 2.8?
dunno, they use the same 5 speed box like 328s and m3's so it must be around the 3.15 mark is my guess. They do 60 in under 7 secs
