Can anyone recommend a fault code reader compatible with the wife's E36? Needs to be able to retrieve ABS codes. Its a '97 318i
john
Fault code reader
- fixedwheelnut
http://www.ebay.co.uk/sch/i.html?_npmv= ... SS:GB:1150
Ediabas/INPA software is pretty good if you have an old laptop.
or try the small pocket fault readers that just give basic codes;
Amazon OBD fault code readers
- fixedwheelnut
Most use an older RS232 port to connect the lead.
Some modern leads use a USB but I havn't tried them yet as my old one still works
