Hi Guys,
Scott from scotland on here came to my house spent all morning of his day off to wire my angel eyes lights in and swaped my rear light for the new tinted rear ones only problem we had the side lights on one side of the car wont work we narrowed it down to the fuse but when its replaced the new fuse blows right away ???
PLEASE HELP ?????????????????
Lars
fuses help ???
320Touring
if its drawing enough current to blow the fuse right away, then its probably a short somewhere in the circuit.
check all the connectors and all the earth points
also possibly try replacing fuse with battery disconnected
320Touring
let me know how ya get on!good luck, and glad to see another scot on here!
Guest
Hi,
got a mate to look at it today and he says the car is runing a constant live we couldnt find it PLEASE HELP ???
pm9575
Are the angel eyes a separate kit? In other words did you have to split the glass lense to fit them? most of these conversions wire straight into the original side light connections left and right and so use all the original loom/ relays / fuses. Firstly check that the new wires are not going to ground on the body work. Is there a separate relay with the light kit?
Sometimes the most obvious fault is a poor connection between old and new.
Guest
No you dont have to split the glass etc they came with plugs on the end of the red and black wires which had to be removed as the plug on the car was a diffrent type so both plugs were removed and wired directly into the original wires for the side lights ???
Lars
Lars
