Electric Sunroof Conversion help??
Tan91
Post Wed May 23, 2012 10:32 pm
If you currently have a manual sunroof, to convert to an electric sunroof would you need these:
Loom
Relay
Electric Motor
Switch
Electric sunroof headlining version.
Only asking as I am soon to re-trim the headlining so while its out I though might as well do a conversion.
Also would the electric motor attach to the existing cables that pull the sunroof back / forward / and up positions?
Again any help would be appreciated.
Post Thu May 24, 2012 12:03 am
The cables are the same, but for the best results, everything else should be changed. Use the motor, complete with its mounting plate and guide tubes. Slide the old tubes off of the cables, remove the motor from its mounting plate, slide the cables into the new guide tubes (after thoroughly regreasing them), set the roof in the full tilt position, connect the electrics to the motor, set the motor to full tilt, then refit it to the plate.
Tan91
Post Thu May 24, 2012 12:08 am
Brianmoooore wrote:The cables are the same, but for the best results, everything else should be changed. Use the motor, complete with its mounting plate and guide tubes. Slide the old tubes off of the cables, remove the motor from its mounting plate, slide the cables into the new guide tubes (after thoroughly regreasing them), set the roof in the full tilt position, connect the electrics to the motor, set the motor to full tilt, then refit it to the plate.
Right only thing is that I would be sourcing the parts individually so I have managed to source (not buy) the loom, relay, motor but NOT the new guide tubes and mounting plate, any ideas as to where I could find these?
GooneriC
Post Thu May 24, 2012 3:18 pm
Check user B7 , he might still have a complete sunroof mechanism with all parts.I posted in the wanted section and he was one of the people who contacted me
There are two complete electric sunroof mechanisms selling on ebay as well.
Post Thu May 24, 2012 5:41 pm
I have all the parts you need to convert a manual roof to electric and I am in west London. I can even do the job , if you pay me enough ! :)
Tan91
Post Thu May 24, 2012 7:58 pm
pacerpete wrote:I have all the parts you need to convert a manual roof to electric and I am in west London. I can even do the job , if you pay me enough ! :)
How much you selling the kit for?
