sun roof seal
tcos
question.. sun roof panel, the seal which is attached to the edge of it, is it a easy job to change??? and any idea how much one is. Thanks
Easy - its just pulls off - not sure if you can do the front part without taking the panel out though
They are silly money from the stealers I think
adit
i would say a definite job for when the panel is removed for an easy replacemant Terry. i have sold a few of these
[quote="bss325i"]
What is your reason for replacing it?
sunnyr83
£60+ from dealers.
turkeysneck
What's it like to get the panel out ?
Tan91
For a rubber strip that goes around the sunroof panel, shocker I must say!sunnyr83 wrote:£60+ from dealers.
rich318i
asked at the dealers about them they said ENDED but they said BMW still do any part but have to pay up front and wait.... they told me some one ordered e28 door rubbers and had to wait 18 mouths. in other words they have to make orders up and make them till its worth the while
tcos
one on the car has or is about too fall off, its knachered, Thanks for all the replys.
318isPMK
Grrrmachine
- E30 Zone Wiki / Team Member
For the OP:
http://www.e30zone.net/e30zonewiki/inde ... of#Sunroof
For 318isPMK:
If your drain channels are a bit rusty, you can try this:
1) Get some rust remover from B&Q. It'll come in a plastic bottle, and contain about 30% phosphoric acid. Pour a little bit down the drain channel, and watch it fizz.
2) get some pipe cleaners, a brass brush or any other scratchy metal that you can poke down the drain tubes. Give it a proper scouring.
3) Hoover up any dust and particles.
5) Get some Dinitrol RC900, and spray it into the drain channel. Let it dry for 12 hours, then give it another coat.
6) Let it dry for two days, then spray in an acrylic paint, two layers.
7) Use something SOFT like a bamboo stick or garden cane (so not an old coathanger) to poke into the drain channel to clear any blockage you may have caused.
That'll deal with surface rust for a year or two, maybe more. If your drain channels are properly rusty, then cover them up and sell the car quickly.
For 318isPMK:
polsta
someones just done that but skipped the 1st 7 stepsGrrrmachine wrote: That'll deal with surface rust for a year or two, maybe more. If your drain channels are properly rusty, then cover them up and sell the car quickly.
318isPMK
tcos
as said above, easey to remove with panel in car, now!!!!! need to get one back on before it pi..s down, any one got one???
e30ftw
i have just done mine this week end, i think they are about £40 from cotswolds bmw dealer thats on hear. If you are replacing the seal, trust me its a lot easyer to take the panel out rather than fook about with it in place.
I just followed this
http://www.e30zone.net/e30zonewiki/inde ... he_Sunroof
The only problem i had was one of the torx heads rounded off because they were THAT stiff , so i would spray some penetrating oil on them first. The only other thing is lining it up again after you have put it back, not hard per say just a bit of patience.
good luck
good luck
adit
tcos wrote:...any one got one???
adit wrote:...i have sold a few of these
[quote="bss325i"]
- **BANNED**
This is a wind seal,not a water seal.tcos wrote:as said above, easey to remove with panel in car, now!!!!! need to get one back on before it pi..s down, any one got one???
Water that gets past the wind seal should drain via the 4 drain holes...but these do get blocked...
318isPMK
Sanchez
Ive just taken my rusty one off about 30mins ago. Lineer pulled down and pushed back then 6 torx headed bolts undone and its free.318isPMK wrote:what about colouring them again when they are faded? I dont trust myself to take off the sunroof
318isPMK
