E30 alarm help please!!!
smunro90
Post Tue May 22, 2012 6:12 pm
Hi I've been having problems with my alarm lately, whilst driving along sometimes it randomly locks me in. I'll unlock it and it just keeps locking, this isn't the worst of my worrys. It also just decides to arm (when locking via fob) but not lock the doors. Then I try and lock the doors and the central locking fails. It's driving me mad just trying to lock the car. I had issues the other night of the alarm going off at 5 in the morning but think it was the book sensor as had a fiddle and this has stopped.
I've found that the unit is a Serpi Star / Gemel GR-480 apparently its fitted from factory (it looks it). Ive done some research but can't find anything. I hope someone can help or point me in the right direction thanks.
threelander
Post Tue May 22, 2012 6:37 pm
did you try reprogramming it mate.what kind of fob is it is it the one with the corner cut of it.also when the red button is pressed does the light on the fob flash or is it a constant light as i can help reprogramming if it flashes.also if the alternator or battery is dodgy it can be mad mine used to come on while i was driving lol
smunro90
Post Tue May 22, 2012 6:43 pm
I haven't done no, no its black with two grey buttons (one ribbed one smooth) and a red led In the middle. I think its the same as the "red button" fob, but instead of red its ribbed. Yes it flashes once when pressed once.
threelander
Post Tue May 22, 2012 6:52 pm
right i found it buddy pm me your email and i will send you ifo ok
smunro90
Post Tue May 22, 2012 6:56 pm
Pm'd thanks
threelander
Post Tue May 22, 2012 7:03 pm
sent mate
smunro90
Post Wed May 23, 2012 5:10 pm
Right I changed the battery's in the fob's and the alarm is now working :) after resetting the fobs though, thanks three lander. But the doors still randomly lock whilst driving?
threelander
Post Wed May 23, 2012 5:36 pm
no worries mate just glad i could help with the alarm.now the problem could be one of your central locking accuators but i know nothing about them sorry.brian moore is the man you need for that mate
Post Wed May 23, 2012 7:30 pm
The random locking is almost certainly caused by the alarm. The OE central locking is ultra reliable, and doesn't have any known faults, OTHER than those caused by external things, such as letting the ECU get flooded, power feed problems caused by electrolytic corrosion, and the odd mechanical failure of a lock motor.
Disconnecting the lock and unlock request wires between the locking ECU and the alarm will prove the point.
