These any good? Grills
Idol
Post Mon May 21, 2012 9:30 pm
Anyone know if these are any good? I know there's a lot of OEM homo's out there but their cheap as chips!
http://www.clevelandpanels.com/bmw/bmw- ... -7417.html
adit
Post Mon May 21, 2012 9:41 pm
never used them but plastic is plastic, it's not like they are structural or can rust is it?
most people on here would use good originals though i reckon
[quote="bss325i"]
Idol
Post Mon May 21, 2012 9:45 pm
Yeah your prob right, not sure how much originals are? But thought this could freshen the front up lovely with shiny plastic!
Was just asking to see if people knew if they fitted ok?
polsta
Post Mon May 21, 2012 9:54 pm
check out the ebay link to that autoglym dye in the carpet thread above...that says dyes plastic etc too, wonder what that stuff would be like on a faded grille ?
plastic is plastic, but it would depend on the quality and feel, if it was as strong/firm as the oem or felt cheaper and thinner and more flimsy with ropey edges etc ? although £8 isnt much to gamble
samuraibaz
Post Mon May 21, 2012 9:59 pm
secondhand OEM\your current OEM & a quick respray over cheap flimsy imitations mate! Non BMW is always false economy unless motorsport standard.
e30mtech
Post Mon May 21, 2012 10:10 pm
be they suck and brake easy
G-Bear
Post Mon May 21, 2012 11:28 pm
This was back in April, so I doubt the price will have change ld much. £40 odd pounds difference..
http://www.e30zone.net/modules.php?name ... 1131876092
Jozi
Post Tue May 22, 2012 12:27 pm
I refurbed my grills using Gtechniq C4 Trim Restore, thorough cleaning and then apply the stuff. It's not the cheapest but the grills came out great
Bit more time consuming and more expensive than the ones linked above but at least they will fit as they should.
zaust
Zone day release
Post Tue May 22, 2012 1:55 pm
Just get a heat gun on your old ones brings the oil back to the surface.
M30 Tech 1 Touring on gas.
Idol
Post Tue May 22, 2012 5:02 pm
zaust wrote:Just get a heat gun on your old ones brings the oil back to the surface.
Yeah? not heard this one! Does it work well?
Idol
Post Tue May 22, 2012 5:04 pm
G-Bear wrote:This was back in April, so I doubt the price will have change ld much. £40 odd pounds difference..
I require 2 matey, bit steep when its 2 ya got to buy!
zaust
Zone day release
Post Tue May 22, 2012 6:39 pm
Yep, but if you f it up worst way you've already committed to buying replacements in your mind any way.
G-Bear
Post Wed May 23, 2012 7:25 am
Yep, I wasn't saying if it was worth it or not, that's up to you. Was just digging out a recent price for you.. :D
