torsen limited slip differential or..
Which LSD for a 325 Cab
3.64
6
46%
3.73
2
15%
3.91
4
31%
Other
1
8%
Total votes: 13
BMWE30325
Post Mon May 21, 2012 6:49 pm
how would an z3 torsen limited slip differential 3,15 be to drive on a m20b25?
http://allegro.pl/dyfer-szpera-bmw-z3-3 ... 61207.html
what would you rather have an used torsen or an fully rebuild normal lsd ? and which would be somewhere in the middle of fun driving and motorways 3.64 3.73 3.91 ? or i can choose to have anyother ratio
http://allegro.pl/szpera-bmw-e30-duzy-d ... 30366.html
my friend is going to poland and is going to bring me one of these which one should i choose? and which ratio and whats the 1.5 WAY , 2 WAY all about?
BMWE30325
Post Mon May 21, 2012 6:50 pm
oh and my current 4.10 open diff gave up after some fun lol
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon May 21, 2012 7:03 pm
It would make it very very sluggish. The lowest ratio diff fitted to the 325i was a 3.64, and some people have tried fitting the 3.45 ratio from the diesel E30s and reported a significant drop in acceleration. Going all the way down to 3.15 will make the car pull away like a bus.
4.1 would make a 325i very lively...
BMWE30325
Post Mon May 21, 2012 8:47 pm
Grrrmachine wrote:It would make it very very sluggish. The lowest ratio diff fitted to the 325i was a 3.64, and some people have tried fitting the 3.45 ratio from the diesel E30s and reported a significant drop in acceleration. Going all the way down to 3.15 will make the car pull away like a bus.
so which one is somewhere in the middle?
Grrrmachine
Post Mon May 21, 2012 8:49 pm
3.64 for cruising, 3.91 for acceleration, 3.73 for a compromise.
BMWE30325
Post Mon May 21, 2012 9:00 pm
Grrrmachine wrote:3.64 for cruising, 3.91 for acceleration, 3.73 for a compromise.
ok thanks for the info i'll think the 3.91 would be good as i dont use the car to often on motorways :) and if i do its not going to be too bad?
Post Mon May 21, 2012 9:18 pm
3.15 torsen diff. needs to be used with a direct fifth gear box, such as that from an E34/36, preferably left attached to a 2.5 or 2.8 M50/52 from the same car.
BMWE30325
Post Mon May 21, 2012 9:32 pm
Brianmoooore wrote:3.15 torsen diff. needs to be used with a direct fifth gear box, such as that from an E34/36, preferably left attached to a 2.5 or 2.8 M50/52 from the same car.
so it would be ideal for an m52 conversion with the e36 gearbox?
Post Mon May 21, 2012 9:53 pm
a correct 325 ratio. I'd be looking for a 3.73 or 3.64
BMWE30325
Post Mon May 21, 2012 10:00 pm
Simon13 wrote:a correct 325 ratio. I'd be looking for a 3.73 or 3.64
are these the ratios that where originally fitted to 325?
gooseygander110
Post Mon May 21, 2012 10:07 pm
3.91 is awesome fun !!!! probably crap on motorways...... awesome for grin factor though !!!
redcar
Post Mon May 21, 2012 10:13 pm
LOL! winkeye
Weren't the facelift "sports" fitted with a 3.91. Was the 5th gear ratio on the sport gearbox the same as a standard 2.5? Get a good gain in acceleration :D
Post Mon May 21, 2012 10:18 pm
A 3.15 on an E34/36 box is the equivalent of a 3.89 on an E30 box, so will be a 'sport' ratio, rather than an 'economy' one - somewhere between the 3.76 and the 3.91.
Post Mon May 21, 2012 10:23 pm
And 3.91 on 325i tourings and tech 2 sports.
BMWE30325
Post Mon May 21, 2012 11:46 pm
one more question my car was an 320 1991 and not sure if it has the small case or medium case diff and if the large lsd diff i am going to buy will fit straight on?
mrLEE30
Post Tue May 22, 2012 4:03 am
Yes it will bolt on.
Grrrmachine
Post Tue May 22, 2012 9:56 am
I should have put this here ages ago
http://www.e30zone.net/e30zonewiki/inde ... fferential
Ziggy
Post Tue May 22, 2012 10:15 am
3.73 is nice on a 2.5. Just that bit less buzzy than a 3.91 without blunting things too much.
Post Tue May 22, 2012 1:24 pm
Ziggy wrote:3.73 is nice on a 2.5. Just that bit less buzzy than a 3.91 without blunting things too much.
Fully agree! One of the best mods. I ever did to my red touring.
Post Tue May 22, 2012 1:31 pm
For a cab it just seems a waste to me.. :?
Post Tue May 22, 2012 1:45 pm
Jhonno wrote:For a cab it just seems a waste to me.. :?
blue30
Post Tue May 22, 2012 5:12 pm
I ran a 2.97 on my 320i for a while to see what it was like,
Nice on the motorway flying along with hardly any revs on. Foot on the floor for any kind of incline though.
No real acceleration to speak of in the lower gears, and huuuuuge gaps between the gears. Makes for a very lazy driving style.
BATTS91
Post Tue May 22, 2012 7:19 pm
sorry to hijack but do the 3.15 diffs come in open or just lsd , what car can it be found on and a rough price so i dont have my knackers tied up ??
Barx325i
Post Wed May 23, 2012 12:49 pm
1, 1.5, 2 way denotation refers to the direction in which the diff will actuate.
1 way, the diff will only lock when accelarating
2 way, the diff will lock with the same force when accelarating as with engine braking
1.5 way the diff has 2 separate pre determined lock ratings. Most likely a greater lock (shallow ramp angle) on accelaration, and a lower lock on engine braking.
Torsen, irrespective of the ratio is a torque sensing setup driven intirely by gears. It requires torque input to determine where to deliver torque. Not so good on loose ground where lack of grip lowers the torque sensing aspect, ideal on the road though..
BMWE30325
Post Wed May 23, 2012 1:04 pm
ok thanks for the info by the time i'l get my diff dose any one have an open diff for sale so i can get my car back running on the road :D
