Got a perfectly good battery
Captain_Birdseye
Post Fri May 18, 2012 2:25 pm
but it's flat - is it worth flogging on here? I've got a jump starter box so I guess someone could come and buy and then just take the car on a long drive....? Dunno.
Post Fri May 18, 2012 2:45 pm
Batteries don't like going flat..
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri May 18, 2012 3:06 pm
You've got a perfectly good flat battery? That's handy, I've got some mint condition tea bags, only brewed once. Want to trade?
Captain_Birdseye
Post Fri May 18, 2012 3:19 pm
Should I keep the good one as a spare and use my flat one as my main one, zapping it with the power pack when it won't start?
Grrrmachine
Post Fri May 18, 2012 3:21 pm
I'd suggest taking it to be load-tested before you do anything. Have a pro check it out, and if it comes back good then they'll advise on how to recover it.
Remember, batteries are just big chemical packs, and they don't take kindly to being abused. A long slow trickle charge is much better for them than jump-starting and booster packs; zap it too often and explosions are not unheard of...
http://www.e30zone.net/e30zonewiki/index.php/Battery
I have no idea what you are going on about.. :?
Captain_Birdseye
Post Fri May 18, 2012 3:25 pm
Jhonno wrote:I have no idea what you are going on about.. :?
i've got 2.
Dezzy
CR24v it's a lifestyle
Post Fri May 18, 2012 3:27 pm
You've a perfectly good battery that you want to sell, a flat on on you chariot, yet your asking what you should do????
That's got to be a new record! :mad:
Captain_Birdseye
Post Fri May 18, 2012 3:28 pm
Grrrmachine wrote:I'd suggest taking it to be load-tested before you do anything. Have a pro check it out, and if it comes back good then they'll advise on how to recover it.
Thanks.
What does this mean:
"Normal quiescent drain on an E30 is around 30mA" ?
Captain_Birdseye
Post Fri May 18, 2012 3:29 pm
Dezzy wrote:You've a perfectly good battery that you want to sell, a flat on on you chariot, yet your asking what you should do????
It's only cos I've got one of those zappers so I can use both. But ye I see your point.
See that is how I read it.. :mad:
Grrrmachine
Post Fri May 18, 2012 3:30 pm
It means that when everything's plugged in but the ignition's not turned on, then the battery will be drained by that amount.
Morat
Post Fri May 18, 2012 3:31 pm
Buy a battery charger. One of my best ebay purchases ever.
andyp
True Old Skooler
Post Fri May 18, 2012 3:56 pm
stevie comes to mind
