Difficulty in Locking/Unlocking Driver Side Door.
Tan91
Post Thu May 17, 2012 11:09 pm
Basically when I Lock the car it has a very vague dead feeling, as in it is too smooth when locking, and when I try to dead lock the car it sort of springs back to the vertical position.
However when I do manage to get it in the dead-lock position (horizontal), and I try to unlock it it will not move without persuasion i.e. forcing it a little bit then it opens after a struggle...
Help me as it is really f***ing me off :cry:
Thanks in advanced
Tan91
Post Thu May 17, 2012 11:11 pm
Forgot to mention the passenger side works fine, although it does not have the dead-lock feature it still springs back and locks nice and solid, only thing is driver side is weak and sluggish.
sunnyr83
Post Fri May 18, 2012 12:26 am
Do you need to dead lock it? Forcing it open again and again could snap your key.
As far as i know you have to give it some to dead lock it but not struggle as you say.
WD40 FTW. :D
BenHar
Post Fri May 18, 2012 11:26 am
Probably need to replace or rebuild the lock.
http://www.billswebspace.com/BMWE30Door ... ebuild.htm
Ben
mcbonio
Post Fri May 18, 2012 1:45 pm
Your turd not have central locking? What year is it?
Billwill
Post Fri May 18, 2012 1:48 pm
That is a nice link supplied by Benhar.
If you cannot get the re-build kit then with the barrel assembly removed...check that with a key inserted fully the brass tumblers are all flush with the side of the barrel.
If not...ie. some are protuding...then file them down flush, while the key is inserted. :)
Tan91
Post Fri May 18, 2012 1:51 pm
sunnyr83 wrote:Do you need to dead lock it? Forcing it open again and again could snap your key.
WD40 FTW. :D
I've tried WD40 although it makes it slightly smoother still a numb feeling if you catch my drift...
BenHar wrote:Probably need to replace or rebuild the lock.
Ben
Where is the rebuild kit available from??
Tan91
Post Fri May 18, 2012 1:52 pm
mcbonio wrote:Your turd not have central locking? What year is it?
I have central locking, works fine from the boot and passenger side, just recently been getting sluggish and a retarded feel when locking, and always tries to spring back to the vertical position!
mcbonio
Post Fri May 18, 2012 1:56 pm
I mean don't you have central locking, activated with a button fob?
Tan91
Post Fri May 18, 2012 1:57 pm
mcbonio wrote:I mean don't you have central locking, activated with a button fob?
Nope
Rtaylor2208
Post Fri May 18, 2012 1:59 pm
Dealer Only
Dont think there was remote locking on the E30 as new, most likely added afterwards
Tan91
Post Fri May 18, 2012 2:02 pm
Would you know how much?
Rtaylor2208
Post Fri May 18, 2012 2:09 pm
When I checked with cotswalds (traders section in here) it was just under £20 delievered. That was last year so may have went up a little.
peeweemad
Post Fri May 18, 2012 8:50 pm
I had this problem with mine untill I noticed a slight twist in my key. Put my key in a vice for a day to straighten them up and havent had a problem since. Might be worth while checking exspecialy if youve had to force the lock.
Hth.
Tan91
Post Sat May 19, 2012 6:34 pm
cheers guys much appreciated will get that sorted now!
Tan91
Post Sat Oct 13, 2012 5:00 pm
Rtaylor2208 wrote:When I checked with cotswalds (traders section in here) it was just under £20 delievered. That was last year so may have went up a little.
Do I just ask for a lock rebuild kit or are the specific part numbers I need to order?
**BANNED**
Post Sat Oct 13, 2012 5:29 pm
Lock rebuild kit for E30 should be enough for most stealers.
What you get is a bag of bits to enable you to build up a replacement lock assembly for your driver/passenger door(bear in mind that these kits are specific to driver or passenger side)the instruction sheet is,unsuprisingly,written in German...I suggest that you dismantle your existing lock carefully so you have some idea of how to build up the new one.
Start by drifting out the roll pin at the inner end,then the thing comes apart with ease.Note that the 'fingers' that slide into the lock barrel have a number stamped into them,try to keep these in the correct order for your replacement lock,believe me,it saves hours of fiddling to get them in the correct order :o:
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Oct 13, 2012 5:41 pm
daimlerman wrote:I suggest that you check the Wiki article for a comprehensive step-by-step guide with photos. More info here:
http://www.e30zone.net/e30zonewiki/inde ... ck_Repairs
Fixed :D
**BANNED**
Post Sat Oct 13, 2012 5:47 pm
Fixed :D
Cheeky bugger! :D
