Ok just scraped all the corrosion, old paint and crud off the seam. It looks like it has a hairline crack in it, the bush has also collapsed, so I can only assume the shock has transmitted to the rear beam and cracked it.
You can see in this pic the space between the top bush plate and the rear beam bush seat.
