rear fog
jimmypee
Hi I have front and rear fog switch. The front works. My question is does my e30 325 touring have a rear fog light. The dash light doesn't light with the switch. Which fuse and relay does it run off the same as the front fogs?
Grrrmachine
- E30 Zone Wiki / Team Member
All UK cars have to have a rear fog for the MOT.
http://www.e30zone.net/e30zonewiki/inde ... #Rear_Fogs
All Fuse info is in the Wiki too:
http://www.e30zone.net/e30zonewiki/index.php/Fuse_Box
jimmypee
I've checked the fuses and swapped the relays about and still no joy. I'v ordered a switch hopefully that will be the problem
Grrrmachine
Seems daft, but have you checked the bulb?
jimmypee
Yeah i bridged the wiring behind the switch and it worked just ordered a switch off ebay. Cheers
BenHar
The switch can be taken apart and cleaned. That's all mine needed.
Ben
Ben
That's all they ever need! Very easy to do.BenHar wrote:The switch can be taken apart and cleaned. That's all mine needed.
Ben
