thought i'd stir this up in this bit as we all look in here more
The B3 as some of you know is going manual.
Heres my stash, 5 speed box and 2.93 LSD being the main bits here. I picked this lot up along with the prop and a couple of other bits off an early 328 sport in my local scrappy. Couldn't believe my luck especially when he said £80 for the box and £50 for the slipper. The other bits came free. I had the pedals, hardline for the clutch hydraulics and clutch slave/master left from my old 328. Plus a braided clutch line, no clutch delay valve wrongness either. So not going too bad on the money front
Ignore the M20 flywheel as i picked this lot up today
Valeo solid flywheel and clutch kit for a e36 328. List price from ECP is £450 but thanks to powellys "contact" i got this little lot for cost plus 5% so £189.
Yes its heavier than an M20 setup but i think theres some good reasons to stick with this. Torque being one factor. This isn't no e30 either as theres probably 200kgs extra weight in the car itself to haul about. 9inch rear rims.
I just couldn't had a cheaper result, yes its heavier but the clutch is much more manly to take it. I only want to be here once
Very similar to the dual mass really, its 11kgs. It won't be once it leaves my Dads workshop for a trim on the lathe!
Whats the dual mass weigh on these anyone?
I got the scales out and had a tinkle
This setup with clutch also is 18kgs
A stock M20 setup is 15kgs
So a lighter M20 flywheel and clutch is going to be around the 13kgs total mark for most people.
I'd like to know the stock weight of the clutch and dual mass on a e36 328i for comparison.
So for the price of a 6 speed box where 5 speed manual with a slipper and a brand new clutch flywheel. I like this idea alot more plus with the manual 328 gearing it will have good m-way legs and still be quick.
All i really need is another alpina gearnob if anyone has one they'd like to sell.
I also had the rear anti roll bar off the sport as it had "anus" suspension and this bar 18mm thick compared to the stock 14mm item on the B3, if it upsets the handling i'll take it off.
Rims are in for refurb and theres a gold decal kit to go on! So that will only leave some bigger front brakes and it will be done for now.......................
