Post
Fri Apr 13, 2012 11:57 am
Part 7 is what needs to be replaced, and as said above, E46 cab. ones are identical in shape, size and appearance, but are stronger.
Part 12 in the lower pic. is not the correct part, so should be replaced, and make sure that parts 6 are in place (incorporated into the dust cover on standard dampers).
Very simple DIY job to replace; no need to even jack the car up: Unscrew the two 13mm nuts in each of your pics., undo the 19mm bolts that holds the bottom of the dampers to the hub carrier, and remove the damper and mount together. Hold the square section at the top of the damper firmly in a vice, and unscrew the big nut in the middle of the mount. Put it all back together, but do not fully tighten the 19mm bolt at the bottom of the damper until the suspension is at normal ride height.
Buy genuine mounts from BMW.
