Speedo and rev counter not working
vendetta
Post Wed May 25, 2011 8:03 am
Got in the moredoor this morning and the speedo isn't working it's been fine any ideas
Post Wed May 25, 2011 8:47 am
Checked fuse 12?
vendetta
Post Wed May 25, 2011 12:04 pm
That was the problem Thanx
Post Wed May 25, 2011 1:25 pm
Unfortunately, that's just a symptom of the problem, and not the problem itself. Fuses don't fail without a good reason.
It's given you a warning that all is not right. Next time it might just incinerate the car.
A wire from this fuse goes to the audio system, so, considering the state of some (or even most) of the 'installations' I see, this is where I'd start looking.
Relevant wire is red/green.
Rtaylor2208
Post Wed May 25, 2011 2:10 pm
Sorry to hijack, Brian my speedo stopped working after the last owner fitted a headunit could this be the same issue? Still havn't had time to get round to fixing mine.
Post Wed May 25, 2011 2:19 pm
Rtaylor2208 wrote:Sorry to hijack, Brian my speedo stopped working after the last owner fitted a headunit could this be the same issue? Still havn't had time to get round to fixing mine.
Almost certainly related!
vendetta
Post Wed May 25, 2011 2:27 pm
All the wires for my sound system
Are just hanging loose in a mess what can I do to stop it popping also my drivers side dipped headlight keeps popping
Post Wed May 25, 2011 6:38 pm
vendetta wrote:All the wires for my sound system
Tidy them up and make sure all are insulated properly.
fuse or bulb?
vendetta
Post Wed May 25, 2011 6:48 pm
Fuse
Rtaylor2208
Post Wed May 25, 2011 9:56 pm
Brian your a legend all it was was the fuse, I sorted out all the audio wiring when I put a new headunit it. So put a new fuse in number 12 and all is working, even the econometer, just another 10 jobs still to do.
nathans
Post Fri May 11, 2012 1:28 pm
sorry to bring this up again, but where should the red/green wire go, is it the ignition live to the stereo? cheers
Post Fri May 11, 2012 2:16 pm
Anything with red as the main colour is permanent live, or closely associated with permanent live.
It's the radio memory feed.
nathans
Post Fri May 11, 2012 3:59 pm
i thought as much, just didn't want to connect it to something and fuck another thing up.
i'll try it in a bit and hopefull i'll have a working speedo.
cheers
