M52 running a bit hot
Jimbob
Post Wed May 09, 2012 1:45 pm
Hi guys,
When driving my car in the evening, no traffic etc, the temp needle sits ever so slightly over half way. However when I get stuck in traffic or it's a very warm day the temp needle starts to waver near 3/4's and slightly above.
I haven't got my part numbers to hand at the moment but I think I'm using the 81c/88c thermostat switch and the E36 aircon fan with Dan's loom. It takes a while for the temp to drop back to halfway once the fan has kicked in so I'm not sure if my fan is just shit or I need to change the thermostat switch to a lower threshold? Or is there a way of modifying the front of the car slightly to increase airflow?
Any help is appreciated!
Post Wed May 09, 2012 2:06 pm
New thermostat?
Hows the rad? What rad?
Jimbob
Post Wed May 09, 2012 2:10 pm
Yeh new thermostat was fitted, however the rad was used from the E36 328i, looked in good nic at the time of fitting.
Post Wed May 09, 2012 2:52 pm
Pics? Rads are long term service items..
Could be a faulty thermostat..
Post Wed May 09, 2012 7:44 pm
If you have the 80/88 fan switch the fan would be running as soon as the needle got to half way, sounds like you have the 91/99 switch to me.
Jimbob
Post Wed May 09, 2012 8:34 pm
The part number I have here is 61318361787, according to realoem that's 80/88 but looks like there's a newer version (61318376440).
Anyone able to confirm the correct part number please?
Jimbob
Post Sun Jun 03, 2012 7:24 pm
Strange things happening with this, I had to use the BMW for work on Tuesday and whilst it didn't run too hot I remember checking to see if the fan was on, which it was. However the other night the temp needle nearly crept into the red, before switching it off I quickly jumped out to see if the fan was on - it wasn't!
I've now run a manual override switch, but in the mean time I need to figure out why it won't come on automatically, could it be a faulty temp switch on the rad?
Post Mon Jun 04, 2012 7:31 am
It is 61 31 8 361 787
Has the switch temps stamped into the side of the brass
Low coolant level or bad connection possibly? Unplug the switch and bridge the terminals to check the fan/wiring
Ianb
Post Mon Jun 04, 2012 1:30 pm
I had exactly this issue, and am running correct temp switch etc - Turned out to be air in the system. My guess is that the air lock landed up near the fan sender. On a 2.8 i'd be scared of thered section of the guage ( mines an M50 ). To bleed it i landed up jacking it up at a ridiculous angle and running till hot, then filling header to top, running at 2k rpm then open bleed screw a bit. It took me a couple of hours but temp much better now.
Jimbob
Post Mon Jun 04, 2012 10:07 pm
Thanks for the response guys, Will it is running with a relay. Based on Dan and Ian's posts sounds like air lock / low coolant level......feck sake was hoping to dodge bleeding the system again :)
shedrool83
Post Tue Jun 05, 2012 7:38 am
I have the same problem .I used the donor cars rad and reckon its that thats the problem ie choked.
Going to get a new one when funds allow.
