Jerky clock needles...
mcbonio
Post Tue May 08, 2012 1:41 pm
Hey fellas,
The needles on my instrument cluster clocks do not move smoothly, they jerk and shudder about as they move.
Is this a symptom of a failing SI board battery?
mcbonio
Post Tue May 08, 2012 2:19 pm
Now that I think back, the service lights have never gone down since I got the car in January. Just answered my own question I think.... 8)
mcbonio
Post Tue May 08, 2012 2:33 pm
Post Tue May 08, 2012 2:51 pm
Some had AA (not AAA as above) type Ni-Cd batteries with solder tags, while later ones had a smaller Lithium battery - you'll need to remove the SI board to check.
mcbonio
Post Tue May 08, 2012 3:30 pm
Before I operate on my turd, can we verify that these are symptoms of low SI batteries?
Jerky, lazy gauge needles
Wandering fuel gauge, + - to an 8th of a tank.
Needles jump when I take the key out.
SI lights have never gone down, always full green.
Post Tue May 08, 2012 4:52 pm
Yes, these can be symptoms. However, also check the brass nut(s) on the back of the temperature gauge, as these often work loose and give an intermittent connection.
