wax oil guns
kitch
Post Mon May 07, 2012 5:14 pm
can you get guns that you can use with a compressor and a can of wax oil? I bought a hand pump one the other day and it doesn't seem that great to me. I've had a quick look on google and ebay but they all seem to have the wrong thread type. As in the gun goes over the top of the tin rather the screwing into it.
Could I use something like this and just pour in a waxoil/thinners mixture?
http://www.ebay.co.uk/itm/SG19-BRAND-NE ... 3cbf5f171e
I'm clueless when it comes to things like this
rich318i
Post Mon May 07, 2012 5:37 pm
yeah my mates got one and uses stonechipwith it
http://www.ebay.co.uk/sch/i.html?_trkpa ... op=3&_sc=1
polsta
Post Mon May 07, 2012 5:41 pm
we waxoilyed a mates car once with the big tin and hand pump- we left the tin by a heater for a bit and kept rotating and shaking it to get it all wamred up and more liquid like, and kept it by the heater as we used it and leaving it for 5/10 mins here and there,also using a thin nozzle on the air gun seperatly to force the waxoil further along the chassis etc, it worked well
Post Mon May 07, 2012 7:06 pm
These cheapo sealey guns are good -
http://www.ebay.co.uk/itm/Sealey-SG14-S ... 710wt_1114
As above if your using it in the cold its best to warm it up first, hot airgun on the can is the quickest way
kitch
Post Mon May 07, 2012 7:34 pm
I left it in a bucket of boiling water when I used it, it sounded like water when I shook it round in the can, jsut didn't spray very well. Thanks for the info :)
Post Mon May 07, 2012 8:25 pm
Gun in the link is just like the one I've been using today on an E39!
Bucket of hot water to keep the waxoil can in, and put the gun in another one between bursts of spraying.
Unless your scalp has a rust problem, wear something (disposable) over your head. Same applies to the rest of your clothes.
rich318i
Post Mon May 07, 2012 8:40 pm
only thing with wax oil id say never use it in wheel arches and exposed areas. when it gets to the summer (hot weather)the waxoil heats up again and becomes active and all mug sticks to it, just use slovent based underseal for them areas
Post Mon May 07, 2012 9:46 pm
rich318i wrote:only thing with wax oil id say never use it in wheel arches and exposed areas. when it gets to the summer (hot weather)the waxoil heats up again and becomes active and all mug sticks to it, just use slovent based underseal for them areas
Exposed areas are the most important places! Even if its got muck stuck to it its still a wax coating on the bodywork, would you rather have mucky wax or mucky rust?
Emm3
Post Mon May 07, 2012 10:19 pm
I used around 15l on my car when I did it. I found that the hammerite wax oil melted quick in hot water but even to date remains tacky however half way through the resto I bought 5l tin made by smith & Allen off eBay this stuff took a lot longer to melt but once applied it left an awesome finish just like a rubber coating even now the areas done in that have been done are dry and not tacky at all
rich318i
Post Mon May 07, 2012 10:48 pm
but it builds up, thats why i recommend joint sealer and stonechip all slovent based, ive been working on metal painting for over 18 yrs now and they are the best. you can go even more and go for a two-pack paint ie what they use now on the 7th brigde
Post Mon May 07, 2012 11:02 pm
Of course it builds up, this is why we wash cars, the joints are mostly already sealed and all are painted/covered from factory, the problem is this stuff shrinks and cracks/chips and then lets water in, why stonechip over stonechip? You are not achieving anything. Just clean it off and waxoil it for a durable, waterproof protection
rich318i
Post Mon May 07, 2012 11:11 pm
were both right lol
bmw9818
Post Tue May 08, 2012 2:36 pm
can the black waxoyl be applied with a brush ? im talking everywhere underside, arches etc, also is this stuff good for cavitys?
http://www.ebay.co.uk/itm/330606494204? ... 1438.l2649
redcar
Post Tue May 08, 2012 2:48 pm
How often do you have to waxoyl inside cavities on an e30?
Also...is there a guide which indicates where all the cavitys are on an e30.
Kedge
Post Tue May 08, 2012 4:29 pm
DanThe wrote:These cheapo sealey guns are good -
Nee to make sure you buy the right Waxoyl can to go with this type of gun. I just bought 1 shutz can to go with the gun then one of the big refil tins to keep topping it up with.
Instagram - Kedge85
kitch
Post Tue May 08, 2012 8:14 pm
I've just realised that. As I've only got 2.5l and 5l tins. I'll have to get a 1l one and top it up. Cheers
