LSD front seal
BrianBimmerHead
Can you get a seal for the input shaft, without having to get the whole gasket set?
And what type of oil does it take?
Demlotcrew
Yes you can, its about £11 from BMW. You will need an LSD additive final drive oil. The input shaft seal can be very tricky to replace.
The best piece of advice i can give you is you borrow a decent and recently calibrated torque wrench, once the new seal is on and the nut is pressing nicely against the flange, tighten the nut to 140nm, no more no less or you will disrupt the delicate preload on the pinion bearings.
Andrew
Andrew
BrianBimmerHead
Thanks for that i dont suppose u'd know the part no. Or where to look for it?
kam-325i
Mark the position of the nut before you remove it, and count the exact number of turns required to unscrew it.
After changing the seal, refit the same drive flange and nut, and tighten it up to exactly where it was before. Use a torque wrench to finally set it to the exact same place, increasing the setting on the wrench until it gets there, and confirm that the setting needed is close to, but not above the 140 nm that Andrew has said.
Demlotcrew
Do you know your differential size?BrianBimmerHead wrote:Thanks for that i dont suppose u'd know the part no. Or where to look for it?
There are two types of diffs fitted to the E30.
Andrew
BrianBimmerHead
I think its a large case as it came out of a sport, are the seals different for each?
Thanks for the help above
Demlotcrew
For the medium case differential the pinion seal part number is: 33 10 1 214 099 £13.80 RRP.
HTH
HTH
Barx325i
seriously tricky, if you're in any doubt it's almost worth having it freshened up completely by our man in inglewood gareth (that's if he still does them)
He can re-seal, re-bearing, upgrade the (20 year old) clutch packs & if you want, machine the ramp angles down, thus decreasing the amount of force needed to engage said clutches.
Either way, approach the job with caution. The fuss is related to the crush washer, which as stated sets the backlash, or as andrew put it, pinion bearing preload.
Crush washers are available, however that will then mean setting the backlash yourself. If you find yourself at this point, measuring the crush washer whilst disassembled is a good idea, prior to reassembly will indicate roughly how much you'd need to crush a new one.
Depending how much you trust your 'feel' backlash can be set by hand.
Barx325i
oh and loctite the thread!
Demlotcrew
To set the preload by hand is impossible, you need a very low reading torque gauge, I use this one: http://www.hroberts-di.com/product_deta ... t=HR010100 0.8-4nm range.
HTH
HTH
Barx325i
sure thing, but I'm talking about the backlash, which you can set by feel/hand, without the use of instruments
Demlotcrew
Back lash is set using a dial gauge.
Nothing on the differential is set by hand. It is a time consuming process, but its relatively easy.
Barx325i
yes yes, when done correctly, but like I said if you have good feel and more importantly good memory, you can adjust it by feel alone.. I didn't notice you making the effort to explain these procedures previously, but you prefer spending this time criticising my input, which is about right...
Demlotcrew
I rebuild my diff once in a blue moon, there is no way i could build up muscle memory from so few builds. I guess its plausible someone who does this every day could.
Barx325i
Making a mental note of the backlash prior to disassembly, so don't have to hold it in memory for too long is where I was at, you'd be surprised how accurate your feel is, but then I'm just gifted.
Demlotcrew
But if the backlash is wrong to begin with, you would assemble the differential incorrectly after replacing expensive bearings.
Barx325i
very true, given that, and depending on what you can deduce from mesh patterns, could potentially mean new cwp..
gareth
Backlash is not set on the pinion so this will not be affected by changing the seal. Backlash is altered by changing the shim sizes on the output flanges. (we will ignore pinion depth here - that is also set by internal shims but does not affect us in this instance)
Pinion bearing preload is set here though and problems from previous incorrect pinion seal fitting here are very common on diffs that find their way to me for rebuild. An incorrectly refitted pinion flange and nut will allow play or excessive preload on the pinion bearings and they will be toast before long. With play, there's a very good chance of also damaging the crownwheel and pinion gears too. It is not possible to do by feel unless you're very brave/lucky as while feeling for play you're also rotating the whole differential and 'feeling' the gear contact and output bearings.
The best way to do it is a full stripdown - the pinion shaft, pinion bearings, crush sleeve and pinion seal are the first parts to go back into a fresh casing. 'Feel' is then a good backup to measurement and correct setting but nothing more.
If you wish to replace just that pinion seal without a full stripdown (not recommended as far as i'm concerned) then very accurately mark the pinion and nut to ensure perfect realignment upon reassembly. If you tighten too much and over compress the crush sleeve, you can't then slacken it back off, it's full stripdown time just to change a £5 crush sleeve so tighten bit by bit and slowly.
Or just send it me me
