335i Lazur Blue Moredoor - Borbets on all Road Legal P12
Sun May 06, 2012 6:31 pm
Very happy chappy when i connected the loom and it started first time with no issues or dash lights :D
I have a clear overhead check panel (bar no washer bottle and a light out ), my rev counter now works as does the swingometer and temp guage.
Also painted the cam cover to spruce things up a bit
Here is a video of it all working, i'am quite pleased with my self if i may say so
Here are the pictures of the mounts, engine does not move and sits exactly where it should
Started pulling carpet out for new interior
all was good on the passengers side
however drivers side will be getting some welding when it goes for MOT
Had enough by this stage and called it a day.
ive got some 4 pot wire covers and m3 batter tray covers on the way so that will tidy engine bay up aswell.
next up is to fit the danthe loom and sort exhaust.
To my supprise i noticed the front end to be full polybushed :mad:
Sun May 06, 2012 6:40 pm
bloody hell ALex, well done, just logged on today :mad:
Tan91
really good fella, progress is positive!
goosiegander
Zonegoose
Sun May 06, 2012 6:44 pm
Woot woot! :D
Cooking on gas!
Sun May 06, 2012 7:22 pm
Thanks Guys
Quick question to the m30 guru's my downpipes under the car are in a v shape so i cannot slide a 2 piece front section on (if that makes sence)
Any ideas here?
Sun May 06, 2012 7:25 pm
No make sense, pics :D
Sun May 06, 2012 7:26 pm
ffs i wont be out for another week i will draw a diagram using paint give me 5 mins :mad:
Sun May 06, 2012 7:29 pm
Nice work Alex :thumb:
Sun May 06, 2012 7:31 pm
well done Alex,Get stuck in Lad :D
Sun May 06, 2012 7:32 pm
Rav335uk wrote:No make sense, pics :D
This is the underside of the car and the black lines are the downpipes going down under the car
Sun May 06, 2012 7:33 pm
magpie wrote:well done Alex,Get stuck in Lad :D
This york meet better go ahead in June :teehee:
Sun May 06, 2012 7:34 pm
looks like the exhaust has been welded wrong then, can you not cut and twist???
Or better still, drive it to Dezzy's place?? winkeye
Sun May 06, 2012 7:36 pm
Rav335uk wrote:looks like the exhaust has been welded wrong then, can you not cut and twist???
Would be a bit loud :mad:
i think the downpipes are all standard to be honest.
the previous owner has welded some pipe to the end of the v and bent it back into line but its a mess
Sun May 06, 2012 7:42 pm
I don't understand why they would weld them so far apart,when they come down through the engine bay together? :mad:
Sun May 06, 2012 7:50 pm
god knows its not as bad as my diagram shows but you get the point :D
Does a bit need cutting and rotating for it to sit right ?
Sun May 06, 2012 8:09 pm
They should come down the same as the M20 manifolds do, no different other than diameter of the pipe size.
Sun May 06, 2012 8:10 pm
strange, wonder if the extra pipe has made them sit funny. Are they suppose to have a bit of flex type exhaust pipe after the manifold ?
Sun May 06, 2012 8:15 pm
No, no flexi,
leeparkes
Once you cut the downpipes loosen the manifold nuts a few turns and you will be able to position them where you want then tighten back up. Simple. :)
This pic shows how there bolted on, you can twist em all over the shop to get a good fit. 8)
Glad to hear its running. :cool:
leeparkes
Sun May 06, 2012 8:18 pm
Hang on, what flex?
Sun May 06, 2012 8:23 pm
i might have a pic lee give me ten mins :D
Sun May 06, 2012 8:33 pm
this is the only picture that shows it, if you look carefully you can see the flex bit which is attached to what looks like the manifold
Dezzy
CR24v it's a lifestyle
Sun May 06, 2012 8:36 pm
I've watched this topic but for some reason I haven't had any emails.
Cracking on Alex.
Your more than capable of sorting that zaust with your welding skills :D
leeparkes
Sun May 06, 2012 8:48 pm
You got a better pic than that Alex. :)
8O
Cant understand why thats there, has this got an E36 rack?
Sun May 06, 2012 8:51 pm
leeparkes wrote:You got a better pic than that Alex. :)
8O
Highly Doubt it, Looks like a i need a new manifold and possibly use current down pipes
What manifold do i have fitted ?
Wish i knew what car it was out of originally. Do the manifold studs snap like m20s 8O
Saying that there is a spare manifold in the boot of it ummm
And Cheers Dez :D
Dezzy
Sun May 06, 2012 9:39 pm
8O
Linkage is standard so must be an E30 rack AFAIK
leeparkes
Sun May 06, 2012 10:44 pm
You never know with this set up Dez.
They are standard manifolds but cant understand why that flexi is on it, they clear the linkage (just) without cutting normally thats why i asked if it was a quicker rack (pinion closer to the manifold)
The only other reason it would be cut is if the engine isnt straight in the bay. 8O
Do you (or previous owner) know who did this swap?
Sun May 06, 2012 10:47 pm
Didn't flexis come on the 7series??
leeparkes
Sun May 06, 2012 11:03 pm
Im sure there all the same like E34.
Sun May 06, 2012 11:12 pm
the flexi bit doesnt look like its been added, so rav might be on the right wave length
engine sits pretty well to be honest
i belive the previous owner bought it allready on the e30 mounts and did the rest
Sun May 06, 2012 11:14 pm
Looks like these
http://realoem.com/bmw/showparts.do?mod ... g=18&fg=05
so it must be out of a 7er then, nice easy life winkeye
Sun May 06, 2012 11:19 pm
Fooking BANG ON :mad:
Sun May 06, 2012 11:21 pm
i wonder if i remove the bits welded on, prehaps it will bend straight so they are lined up together :?:
leeparkes
Sun May 06, 2012 11:31 pm
Never knew the 7's had those fitted. 8O
Alex wrote:i wonder if i remove the bits welded on, prehaps it will bend straight so they are lined up together :?:
Just undo the manifold to downpipe bolts a couple of turns to take some tension off the springs then you should be able to bend them where you like.
Sun May 06, 2012 11:32 pm
Think i will give that a bash next weekend Lee, was planning on putting the interior in next weekend but i need that footwell fixing before i put another carpet in :(
