hartge h26 engine
hoggie
I have been offered a genuine hartge h26 engine in very good condition what kind of money is this engine going for out there
hoggie
hoggie
- E30 Zone Meets/Events Team
Any pics??
Saw this post on the irish forum.
Steve is our resisdent Hartge Nutter, so should be able to help.
hoggie
No i have no pics still undecided about it w
hich Steve is the hartge guru
hoggie
they chuck out around 190BHP if they are fettled right, does it come with the correct ECU?
all that took place was a spiky cam and some porting/head work it's unlikely that it still has the correct head 20 some years later, if it has there will be Hartge markings above the intake,
as for Value thats tricky, if it doesn't have the correct head still and the ECU but in reasonable running condition then it's a £250 B2.5 donk
hoggie
Car and classic had an ad for an h23 the ad is still there automec was selling it they want 700 for it i assume that is the kind of money they are making
Barx325i
that h23 comes with, the ECU, rocker cover, genuine hartge head/cam
If it's complete, then it has some value, I'd check it out, it's not just about the bhp, hartge make nice 'drivers' engines
hoggie
Does it have to have a hartge specific ecu or will the standard ecu do
Barx325i
std 2.5 will do, but to take advantage of the cam & porting, it could either do with the genuine unit or a clone. Steve topless will wax on this.
If the genuine head is still present, it's likely the cam is there too so worth a check. You're looking for something like this:
and if you're lucky, this:
hoggie
Barx325i
I did answer this previously
nohoggie wrote:Does it have to have a hartge specific ecu
yeshoggie wrote:or will the standard ecu do
