Hey up,
Thinking of swapping out my clunky diff but I'm unsure what ratio it currently has. Its a 325i cab, so I know its medium case, but the ratio I'm unsure of. I'm guessing its 2.91 as this was paired with the autobox?
Also, my cab is an automatic, would I benefit from an LSD?
-Mcbonio
325i differential options
RichIS
2.91 seems wrong to me 3.91 maybe? as for a lsd unsure of the benfit would be so noticeble with a auto box
Injections nice....but I'd rather be blown ;)
It'll almost definately be a 3:73. Every convertible i've seen has had this ratio.
LSD is always an upgrade no matter what transmission you have.
There are 3 ratios which are associated with 2.5's.
3:91 from a tech 2 sport. These pep them up nicely off the line
3:73 convertible and Alpinas choice for the C2 2.7's (IIRC)
3:64 from the saloons (and Tech 1 sports) which give a lower RPM on a motorway.
Basically you take your choice as to what you want to do with the car and how you want it to perform.
mcbonio
Excellent info B7.! Thank you!
