Post
Fri Apr 27, 2012 2:49 pm
Copied from that thread:
-------Turbo Drain - -10an
The rule of thumb with turbo drains is: bigger = better. You don't want any restriction, so -10 an is a good size, and should easily support the flow through your turbo. No reason to go smaller than that, IMO.
Parts:
SUM-230003 Hose, Braided Stainless Steel, -10 AN, 3 ft. Length, $16.95
SUM-220087 Hose End, 90 Degree, -10 AN Hose to Female -10 AN, Aluminum, Red/Blue Anodized, $15.95
SUM-220082B Fitting, Fuel Cell, Male Bulkhead, -10 AN, Aluminum, Black Hard Anodized, $12.99
Ebay seller: wyntonm - "T3,T3/T4 Aluminum Turbo Oil Drain adapter" - 5/8", 50.8mm bolt spacing - $18 shipped
** NOTE ** The braided hose I used didn't really work with the slip-on fitting I had going off of the turbo. I had to use a dremel to cut away the outer layer of stainless braid because it was just not going to slip over the barbed fitting. This ultimately weakened the hose and it broke at that fitting when I was removing the turbo one time. I replaced it with some nice rubber line
SUM-220789 Summit® Twist-Tite Hose, Rubber, Blue, -10 AN, 10 ft, $30.95
This was more flexible and much easier to work with. Highly recommended. Although it is also available in black, I prefer to get oil-related fittings and hoses in bright colors so I can more easily track down leaks.
I originally had two -10 an swivel fittings, one on each side of the drain. The drain side was going to attach to the turbo with a -10an adapter (similar to the one I used, except threaded). This would be most secure. Unforunately, the holset compressor housing is so close to the oil drain that you can't physically fit the -10 an fitting. Grinding the fitting down would not have been an option. This "slip-on and clamp" drain is the only thing I could find that would fit. It works fine, 0 leaks. Most turbos you should be able to use two swivel fittings though.
Here's how I attached the hose to the swivel head:
1. Put a very little diswashing liquid on the hose tip.
2. Take the red head off of the swivel fitting.
3. Jam the slightly lubricated hose into the red fitting. It should be pretty difficult.
4. Tighten the blue and red parts of the fitting together tightly. Viola! Leak-free seal!
The most common place to run the drain is the oil pan. Most obvious.
I have read it is preferable to have it above the oil-line. Mine will spill a little oil, but I think it's fine. I originally used a buldhead fitting, but it leaked, so I bought a - 10 an weld-in fitting ($8 shipped from ebay seller wyntonm) and had a local shop weld it on for $40.
NOTE: Be careful where you put the drain. It is best to be above the oil level, and make sure it doesn't interfere with any oil pan bolts (my first fitting totally blocked one of my bolts because I didn't think about it. Doh!).
Here it is finished. I cut 16 inches of hose for the drain and it is plenty long.
