bmw 316i revving
paul_145
my e30 316i will start and run fine but when revved above, 4000 it misfires. idle control valve changed, plugs leads rotor arm and coil, ecu. still no luck. any ideas?
toby
Is the camshaft noisy?
paul_145
no this is a new engine for car, changed engine as old one was very noisy but this ones sweettoby wrote:Is the camshaft noisy?
Billwill
Maybe the AFM?
i'm breaking a complete 316i if you need any parts it's all here on a running engine.
+ a yard full of scrap turds
pipework
i have the same issue with my 318i but mine is very noisy (tappety) and im changing the cam and lifters tomorrow. ill let you know if i find i cure
