Since I have my wee list of chores to do on the cabby to get it through the MOT it was time tonight to get my finger out and crack on.
After what ended up being a totally painless 2 hours I managed to get the car up in the air on stands, front struts off the car and partially stripped, power steering belt off, split steering rack gaiter removed, and a whole bunch of bits out the way to tackle the timing belt.
For once a result, mostly thanks to the WIKI and past advice on here its been a doddle. Not one seized or rounded off nut or bolt.
For me that's a total result as I am far and away from being a mechanic.
Fingers crossed it all goes back together again as easily.
For once and evening well spent
Rtaylor2208
good work m8,that's the spirit keep it up and you'll beat the 'krout' into submission
+ a yard full of scrap turds
grantfk10
- E30 Zone Meets/Events Team
Well done, hope it's all coming together for you ;)
Rtaylor2208
It makes a nice change, some of the other jobs over the last 18 months have been a total nightmare.
Jos
it's nice when you get a wee run like that, can be soul destroying spending 2 hours getting a nut or bolt off! (or removing a waterpump housing bolt from a bloody Peugeot with a snapped stud extractor in it)!
'94 e36 tree climber
Mo13
GEED JOB MATE! looking to do it myself in a few weeks anything you can pass over?
Rtaylor2208
^^ Anything in particular?
Mo13
pictures maybe? just to get to the timing belt.....
Rtaylor2208
Theres a good guide in the wiki that I have been following:
http://www.e30zone.net/e30zonewiki/inde ... elt_Change
Ziggy
The fun bit with the cambelt is starting it after you've changed it for the first time!
Within 10 seconds you then realise that it was actually a remarkably simple job, & you won't be worried at all next time!
Just make sure you check things properly before you turn the key...
