Wheel refurb - diamond cutting
Jozi
I'm looking for someone who is good at wheel refurbs and does diamond cutting.
I have two sets of Borbet B's, one set 7.5J in black and the other set 9J in silver.
The silver 9J's are pretty good and I want the black wheels refinished to match these. Diamond cut spoke face, polished lip, silver paint in the recessed diamonds, between the spokes and rear of rim and then clear coated.
Having spoken to a crowd in Belfast he doesn't think they can do it, they can't guarantee the same diamond cut finish as the 9J wheels. He has done numerous Borbet A's and they always come out with a duller finish than what they originally were. Is there anyone who can guarantee the same finish or is it just not possible?
Kos
they always will come out with a duller finish unfortunately
there is one company that i know of that will do a an excellent almost OEM diamond cut finish and that's diamond styling in Ashford Kent.
Jozi
I thought that might have been the case, you don't happen to know of any? I'll give them a bell and see what they can do for me.
Looks like I might just sell them and keep looking for a set that are silver
kman82
You could try sending them to lepsoms in swindon where they did my borbets Jozi, I'm dead chuffed with them! They weren't able to cut the centres though which if you look really closey sit about 0.5mm proud of the rest of the wheels. Other than that they're wicked!
Jozi
What did it cost you to get yours done? PM if you want. I'll give them a bell tomorrow as well to see what they have to say.
I think I'll end up selling the 7.5's though. And run 9J all round with a shorter spring in the coilovers.
Jos
Did you try Lester Engineering in Lisburn?
'94 e36 tree climber
kman82
They charged me £70 per wheel + vat (£336 total) but that included putting stretched tyres on for me too. I think its £60 a wheel without.
+44 (0) 1793 887222
It wasn't long ago I had mine done now so they should still remember them.... they moaned enough getting the tyres on!
+44 (0) 1793 887222
Jozi
Just tried them there, same story, unless he knows the parameters of how the wheel was made he can't replicate the diamond cutting. 140quid a wheel to!!Jos wrote:Did you try Lester Engineering in Lisburn?
I'll bell lepsoms now and see what they have to say!
Diamond styling emailed me that he can't do it, no reasons or explenation
Jozi
Could you send me a few pics of the finish on the spokes of your wheels so I can see if it's close to being the same as my own?kman82 wrote:They charged me £70 per wheel + vat (£336 total) but that included putting stretched tyres on for me too. I think its £60 a wheel without.
+44 (0) 1793 887222
kman82
I'll have to wash them first!! Will get back to you
Jozi
Cool, let me knowkman82 wrote:I'll have to wash them first!! Will get back to you
Ninja_Penguin
this is what i did...was all sanded by hand. tbh, if you have the patience its worth doing. this was from sandblasted condition. working my way through the grades P80 to P2000 then polish with autosol.
Jozi
Those look really well and good job on polishing!
My problem is the spokes are diamond cut, which is nothing like a polished finish, and it's hard for them to do the cutting so it looks the same as the other wheels.
How much polishing time was put into them?
Ninja_Penguin
yea i know what you mean, i didnt know if you could polish the bits which were diamond cut. being flat n all that.
each wheel took between 10-14 hours. only due to the amount of pitting from the sandblasting.
Jozi
Thats a lot of hrs!
I can polish the diamond cutting out of the good wheels, get the others refinished silver and polish them also but it's not the same. I'd say they will just be sold as is and i'll run 9J all round for the time being.
kman82
All though those polished wheels look really good, I'm not sure i'd want to polish my diamond cut finish. The little grooves are what makes them look really good imo! plus you'd then have to relaquer them after.
I've done a really really bad of cleaning them with a bit of bog role this morning but take a look. Will get better pics at the weekend.
kman82
^ Taken on my knackered iphone too
Jozi
My lip is nothing like that, it's been polished which I thought might not have been original.
Your caps were left untouched or did they cut them also? Do the grooves on the spokes match the caps at all?
kman82
The lip on mine was always grooved. The guy at lepsoms reckons they were opriginal because they came from Germany and apparently its illegal to repair alloys or diamond cut them over there?????.
The rim edge (where it joins the tyre) may well be different as this would have been ground back a bit to take out the kerb rash
The lip is probably more grooved than my current centre caps (and brand new ones) but the spoke face is probabably a little 'flatter'. looks like it has a bit more laquer on it too. The trouble is they cant take too much off when its on the lathe otherwise the centre cap will never fit back on flush - and they cant secure the centre cap to cut it at the same time.
Jozi
Can you notice the spoke face and caps are very different to each other? I might look into sending them there if it's really close! Your diamond cut is clear coated I guess?
kman82
You cant notice it from standing distance at all but if you look really close (like taking those photos) you can.
Assume its clear coat yeah, not really sure.
Bout time your got these sorted mate!
By the way i think i've asked you this before but in your signiture pic, is that front wheel bolted up properly? If so what front drop have you got coz my cab on 35mm has tons more arch gap.
Jozi
Thats just a picture of a random car I found and photoshopped a borbet wheel onto, it was a 4dr to start with as well.
My 9J's a sorted, they just won't fit with the coilovers up front
I'm looking into a shorter spring for them so they will fit (front only, rear is fine) Spring being cheaper than refurbing the 7.5's.
