Diff LSD or POSI ??
Zippys
Does BMW offer a true POSI Diff.?
DHFiS
Whats a true POSI diff?
kam-325i
"POSI" as in GM's POSItive TRACking diff ?????Zippys wrote:Does BMW offer a true POSI Diff.?
If so, its just another name for the same thing, a Limited Slip Differential.
So the answer is Yes, BMW call it a LSD.
Zippys
No clutches, geared for both wheels to spin.DHFiS wrote:Whats a true POSI diff?
Zippys
If BMW lists their Diff "open vs. LSD" and LSD is in fact a POSI then all is well and I need to check on what I have. Thanks.
Standard LSD has clutches, same as all standard LSD's
No clutch ie gear locking diffs are named Torsen
And are available in E30 fitment on a Z3 2.8.DanThe wrote: No clutch ie gear locking diffs are named Torsen
Zippys
Thank you, need to remember "Torsen" Diff for 1990 325i
Z3 2.8 diff. has a 3.15 ratio though, so is unsuitable for use with the normal E30 gearboxes with their overdrive top gears. Need to be used with a direct top gear box, such as the ones that come attached to M50 and M52 engines.
No E30 ever came with a torsen diff, only Z3 AFAIK
