Anyone ever fit a tire this size to the rear of their E30? I know right off I'd have to raise the back end up back up a bit (on -40mm setup right now). Just wondering mostly about the amount of, if any, arch rolling is needed, plus spacers, ET, etc.
Thanks!
Fitting 275 R17's ?
E30_Crazy
Grrrmachine
- E30 Zone Wiki / Team Member
No experience myself, but I remember reading (when compiling the wiki) that 225 is the absolute maximum on the rear, and even then it's a fine balance between rubbing on the lip and rubbing on the shock.
Adding two more inches to that is asking for trouble, unless you're prepared for serious body work - you're not going to be able to roll the arch out 50mm.
Dezzy
- CR24v it's a lifestyle
Why would you want too in the first place?
suchy
- True Zone Relic
Unless we're talking M3?
E30_Crazy
Nah, not an M3.
As to why, I came across a pair of them for free from a mate at work, so I thought I'd look into it.
Dezzy
It's just madness. It would. E alot cheaper, easier and the car will handle MUCH better on the correct size tyres.
Kos
StefanAnghel
