E46 Steering Rack
turkeysneck
Post Wed Apr 25, 2012 6:20 pm
I'm trying to buy an E46 Rack, I've given these part numbers to my supplier but they are telling me these numbers are not recognised.
32136755067 & 32136755068
They also told me they seem to think the M3 E46 rack is probably the one to go for. Does anyone know if the M3 rack is as quick as the 067.
It's cheap enough to buy but not that cheap to find I've bought the wrong one.
Post Wed Apr 25, 2012 9:30 pm
M3 rack is nothing special
turkeysneck
Post Wed Apr 25, 2012 9:33 pm
Ok what do you suggest.
ross2009
Post Wed Apr 25, 2012 9:42 pm
32136755068 this must be recognised its on real oem as a part on the 318ti compact
http://www.realoem.com/bmw/showparts.do ... g=32&fg=10
Turbo M20
v8 project 6.0 twin turbo
turkeysneck
Post Wed Apr 25, 2012 9:45 pm
I gave them that number also. I either need a registration or a chassis number because those number are not working with the software they are using or by directly calling the company that supply the ZF racks. The stupid thing is it's not a lot of money but I need to make sure I get the correct one.
ross2009
Post Wed Apr 25, 2012 9:47 pm
are you dealing with bmw ?
or an after market parts supplier ?
Turbo M20
turkeysneck
Post Wed Apr 25, 2012 9:48 pm
Aftermarket supplier, forget BMW, I'm OK for getting raped financially.
sweep
E46 clubsport one is whats on mine and its spot on
turkeysneck
Post Wed Apr 25, 2012 9:49 pm
OK but I need some information.
ross2009
Post Wed Apr 25, 2012 9:50 pm
turkeysneck wrote:Aftermarket supplier, forget BMW, I'm OK for getting raped financially.
well that prob why they cant find that part number because its a bmw part number its not going to be the same as an after market part thats why it dont exsist
Turbo M20
turkeysneck
Post Wed Apr 25, 2012 9:57 pm
Great, so I need a reg or chassis number from an E46 that had one fitted. That's pretty much killed it.
sweep
Post Wed Apr 25, 2012 9:58 pm
Danthe is the man,see if he can source the rack and pipes/spacers
turkeysneck
Post Wed Apr 25, 2012 9:59 pm
OK
eko
Old timer
Post Wed Apr 25, 2012 10:11 pm
Heres the numbers you need for a ClubSport rack...
7852 974 679
6 755 067
turkeysneck
Post Wed Apr 25, 2012 10:12 pm
Thanks.
e301988325i
Post Wed Apr 25, 2012 10:14 pm
This should sort you out, I would expect a brand new rack to be £1000 exchange, you're a fool if you buy a brand new item IMHO, your E30 could do with the money spent in other places for sure!!!!
last 7 digits of VIN: PC55152
I said:
e30topless said:
lock the wife in there
eko
Old timer
Post Wed Apr 25, 2012 10:17 pm
Heres one on Ebay.
Bit more than I paid for mine but still cheaper than new
http://www.ebay.co.uk/itm/BMW-E46-330i- ... 2a1c9e342c
polsta
Post Wed Apr 25, 2012 10:29 pm
Tony- if you had a set up for an e36 rack, with the pipes modified etc , could you just use a46 rack instead and just swap the rack , or is there more involved ?
whats needed for a full e46 set up exactly and costs ? and im talking for a non pas car full conversion
redcar
Post Wed Apr 25, 2012 10:36 pm
eko wrote:Heres the numbers you need for a ClubSport rack...
7852 974 679
6 755 067
That's the badger winkeye
e301988325i
Post Wed Apr 25, 2012 10:39 pm
eko wrote:Image
numbers from my purple plate:
7852 974 679
6 755 067
006888 0701
last four digits manufacture date perhaps?
I said:
ross2009
Post Thu Apr 26, 2012 7:02 am
that 6755067 is the BMW part number that doesn't come up on real Oem instead it states it as 6755068
we have already given these part number but he said his supplier can't find them they don't exist
these part numbers are for BMW only not aftermarket suppliers which is what he's after
Turbo M20
Jozi
Post Thu Apr 26, 2012 10:25 am
Ebay for these and look for the purple tag and 067 ending part as above. No point getting a new rack, use the money you save else where by going ebay.
turkeysneck
Post Thu Apr 26, 2012 6:20 pm
I can buy a new rack for 145 quid, obviously reconditioned but I'm not spending a 1000 bones on anything.
eko
Old timer
Post Thu Apr 26, 2012 6:25 pm
turkeysneck wrote:I can buy a new rack for 145 quid, obviously reconditioned but I'm not spending a 1000 bones on anything.
Genuine BMW rack?
Id rather have the correct secondhand item than wrong ratio aftermarket?
The one in the Ebay link above will do what you need,probably last for years yet too.
turkeysneck
Post Thu Apr 26, 2012 6:28 pm
Of course it's genuine, just re-conditioned.
I deal in car parts all day long, I don't buy crap. I just get huge discounts because of the huge quantities I buy.
ross2009
Post Thu Apr 26, 2012 6:30 pm
since you posted this thread ive already bought a 067 rack of ebay cleaned it modified it with e30 rods and track rod ends modified the steering, oil lines and spacers and its now all fitted and works a treat and your still on about buying one :mad:
Turbo M20
turkeysneck
Post Thu Apr 26, 2012 6:33 pm
Dan is getting me a used one, I can't get a new one because of the part numbers don't match up. I'm not going on about buying a new one I'm just replying to a post. I want to buy a new one but sadly I can't guarantee it'll be the one I want.
I will have some nice custom made, zinc plated PAS pipe kits available in about a weeks time for anybody that doesnt like bent rusty pipes winkeye
turkeysneck
Post Thu Apr 26, 2012 6:34 pm
I might take you up on that.
ross2009
Post Thu Apr 26, 2012 6:38 pm
abit of heat and abit of persuasion they can look neat winkeye
Turbo M20
Post Thu Apr 26, 2012 6:41 pm
Be careful they dont touch the cross member Ross, looks a bit close there. Rack should also be mounted in the rear holes 8)
turkeysneck
Post Thu Apr 26, 2012 6:42 pm
How much are the pipe kits you are selling Dan ?
ross2009
Post Thu Apr 26, 2012 6:44 pm
there not touching i think its just the camera angle yeah i know they should be in the rear holes but it wouldnt go bk far enough there was some one else on here the other week that mounted it in the front holes and has done lots of miles still checking that the mounting is still stress free and he said it still looks fine
so ill keep my eye on it :)
Turbo M20
Post Thu Apr 26, 2012 6:48 pm
turkeysneck wrote:How much are the pipe kits you are selling Dan ?
Still waiting on the rest of the fittings to come in, wont know for sure until they do but they will be about £120 this time
Karan
Post Thu Apr 26, 2012 7:00 pm
Dan do you know the thread on the rack end banjos as I need to make some pipes up for my conversion,
Karan
