'89 325 Touring speedo reading inaccurate
Podge72
Tue Apr 24, 2012 8:52 pm
For some reason have noticed that speedo is showing wrong mph. I think it's about 9-10% out...any ideas and how can this be sorted as it's really annoying.
Cheers :-x
**BANNED**
Tue Apr 24, 2012 8:59 pm
Tyre size?
Youth is wasted on the young.
Podge72
Tue Apr 24, 2012 9:31 pm
Good point..thery're 15" diameter but not standard alloys. Is that enough or would you need the full rundown. If so I'll have to check in the daylight. Sorry know sweet fa about this sort of stuff, can you tell?!
Captain_Birdseye
Tue Apr 24, 2012 9:37 pm
I don't either, looking forward to find out as my new wheels+tyres together are a bit smaller than standard.
Sanchez
Tue Apr 24, 2012 9:39 pm
Has it got the correct clocks? with the correct coding plug.
Podge72
Tue Apr 24, 2012 10:11 pm
How would I know if it had or not? Is there any way to tell?
Grrrmachine
E30 Zone Wiki / Team Member
Wed Apr 25, 2012 6:30 am
All the info you need on Wheels:
http://www.e30zone.net/e30zonewiki/index.php/Wheels
and Tyres:
http://www.e30zone.net/e30zonewiki/index.php/Tyres
I'd have a look at those numbers first before you start exploring the clocks and coding plug. Remember that the gauge will never be 100% accurate; it overreads slightly.
Wed Apr 25, 2012 7:40 am
With 15" wheels you need 55 profile tyres. If they are something other than that the speedo reading will be wrong.
Wed Apr 25, 2012 9:14 am
Coding plug does not affect the speedo in any way.
Wed Apr 25, 2012 9:24 am
To work out your rolling radius for different size wheels and tyres use this.
www.willtheyfit.com
Podge72
Wed Apr 25, 2012 1:23 pm
Cheers guys. I'll let you know how I get on...
Grrrmachine
Wed Apr 25, 2012 1:39 pm
Rav335uk wrote:To work out your rolling radius for different size wheels and tyres use this.
www.willtheyfit.com
There are two separate tyre calculators in the Wiki link I posted, as well as a table of correct sizes 8O
Wed Apr 25, 2012 3:20 pm
www.willtheyfit.com
I didn't know now did I :D
Podge72
Wed Apr 25, 2012 7:28 pm
Tyre size is 195/45....
Wed Apr 25, 2012 7:31 pm
Podge72 wrote:Tyre size is 195/45....
Well, there's the problem, then!
560mm diameter, when it should be 610mm = approx. 9% error.
Podge72
Wed Apr 25, 2012 10:36 pm
So then, lower profile tyre + wheel = smaller diameter overall size therefore 1 revolution = 9% less than standard hence the increased mph reading....I get it now..it's like being back at school only learning about something you're actually interested in!
So in other words live with it or go back to standard...
Cheers Brian.
Wed Apr 25, 2012 11:29 pm
The tyres you have account for most, but not all of the error. The speedo will still read less than actual speed, even with the correct tyres.
This is because the speedo is not like the other instruments - those are all provided by BMW for your convenience and information, whereas the speedo is there by law, and it's purpose is not to inform you how fast you are travelling, but rather to enable you to conform with whatever speed limit is applied to the road you are on.
To ensure that you do not unknowingly break a speed limit, all speedometers intentionally indicate a higher speed than you are really travelling at.
Jos
Thu Apr 26, 2012 8:53 am
Hence the reason why you can be done for 31 in a 30, if you're doing 31 on radar then your speedo probably reads 35!
'94 e36 tree climber
Suki_BiH
Thu Apr 26, 2012 9:40 am
you have a tire size problem in combination with manufacture default higher speed readings.
earlier models have a calibration option inside the cluster, i'm not sure for later models :/
Even though I walk through the valley of the shadow of death, I fear no evil, for You are with me; Your rod and Your staff, they comfort me.
(23:4)
