m20 loom
Post Mon Apr 23, 2012 11:29 pm
What modifications do i need to do to fit an m20 engine loom to an m30 ?
do any wires need extending?
Do i still need to modify certain wires for rev counter etc ?
reason i ask is because i allready have an m20 loom and my m30 one is butchered
leeparkes
Post Mon Apr 23, 2012 11:52 pm
Im not 100% sure but i seem to remember something about the TPS, its either the wires need extending or the 3 wires are the wrong way round.
Also you will have to work out the injector part of the loom, M20's have that little round plug under the inlet and it may be too messy for your OEM look. :)
Thought topless was giving you one?
Post Mon Apr 23, 2012 11:55 pm
That's what I thought too Lee,that there was a bit of rewiring to do.
Alex, no reply from the other guy about the loom???
Post Mon Apr 23, 2012 11:57 pm
you could adapt an early K jet loom, but the TPS plug and afm won't reach
the oil sender will need lengthening too :mad:
leeparkes
Post Tue Apr 24, 2012 12:05 am
Thinking about it it could be the AFM wiring the wrong way round, ie the pins in the wrong place. :mad:
Just get an M30 loom it will save a lot of chew.
Andyboy
Alpina Colada
Post Tue Apr 24, 2012 8:20 am
The Man-whore!!!!
Post Tue Apr 24, 2012 6:34 pm
Andyboy wrote:
The Man-whore!!!!
He was, but i need to get down and god knows when that will happen
i have a complete m20 engine in he garage with loom
I dont mind altering bits and bobs with solder and heatshrink and do it all properly. may remove the loom on it and fix it with solder and heat shrink. its the crimps and block connectors i hate on something as important as the engine loom
leeparkes
Post Tue Apr 24, 2012 11:30 pm
Alex wrote: may remove the loom on it and fix it with solder and heat shrink.
Id rather do this than graft an M20 loom on.
A rough guess id say the M30 loom you have is from a late engine, the C101 is similar to an M50 one hence why you have loads of wires cut.
Bristol_jer's loom was like this so he cut the plug off and grafted a M20 C101 plug to it.
His car is running now so drop him a pm. 8)
Post Tue Apr 24, 2012 11:32 pm
That's a good way to sort ut the issue Alex, on the thread listed above, all the wires have been named too. :cool:
Post Wed Apr 25, 2012 6:22 pm
Excellent.
So i remove my c101 of my m20 engine and wire it to the m30 one
i assume the aftermarket ush button start fitted is a case of removing it all and joining the wires back together does yellow black ring a bell ??????
8)
leeparkes
Post Wed Apr 25, 2012 6:40 pm
Yes iirc yellow/black is for the starter.
It really depends how the push button starter was plumbed in, does it still start with the key?
Post Wed Apr 25, 2012 6:42 pm
No not with key, inside the c101 the yellow and black has been chopped and its also been chopped at the starter i assume i just need to connect it all up. Think i took a few pics in my thread
leeparkes
Post Wed Apr 25, 2012 6:52 pm
Id say yes, maybe put an inline fuse there just in case. Has any of the body loom been hacked?
Just been to look at your pics again in the other thread. 8O
Post Wed Apr 25, 2012 7:31 pm
Body loom is ok i think, it will all sort out with solder and heat shrink, any idea what the live wire going to injector loom is ?
leeparkes
Post Wed Apr 25, 2012 7:41 pm
You should have a permanant live coming off the loom its about 4 red wires bunched together and they will be near the coil/relays.
Post Wed Apr 25, 2012 7:42 pm
So i use one of them for the wire to the injector loom
Apprecaite all your help Lee and Rav
8)
