Wings for 3251 cabriolet
Wilkie1
Am receiving mixed messages as to whether I can fit a standard wing to my 325i cabriolet - it seems not but I am unable to locate one for my cab - any suggestions? Thanks in advance, Wilkie
Jim320i
- E30 Zone News / COTM Team
Welcome to the zone pal...
Cab wings are different yes, they are deeper and longer at the bottom to my knowledge... You might want to put a wanted ad up in the wanted section...
Are you after a certain colour or any in good coniditon? Also, whats your location pal?
cecotto479
- Caution Unreliable Seller
The very lower portion is different. A standard wing will not fit, but should be relatively easily modified by a decent panelbeater to fit without too much trouble.
I have excellent second hand ones available for about half the price of new
1981 E23 735i
Wilkie1
Thanks for the replies - I am being told that the cab wing is about an inch longer and that the last inch is only spot welded on and should be capable of being taken off of my wing and spot welded back on? Make any sense? Am happy to buy a second hand wing as it will need to be sprayed in any event. If its a fairly simple modification for a panelbeater I think I will buy a standard wing and have it modified - Wilkie
Jim320i
There will be plenty of people on here with Cabbie wings for sale... I'm one of them shortly. Whats your location mate and people might be able to get you some prices.
- **BANNED**
Correct!Wilkie1 wrote:Thanks for the replies - I am being told that the cab wing is about an inch longer and that the last inch is only spot welded on and should be capable of being taken off of my wing and spot welded back on? Make any sense? Am happy to buy a second hand wing as it will need to be sprayed in any event. If its a fairly simple modification for a panelbeater I think I will buy a standard wing and have it modified - Wilkie
The spot-weld join on a cabbie is concealed by the trim strip that runs the length of the sill.
Although I provided my bodyman with two decent s/h cabbie front wings,he still deemed it nesessary to make one lower replacement bit.My guy,though,employ's a youngster that he is training,so told me that it was part of his 'learning curve'!
Youth is wasted on the young.
Wilkie1
Thanks mate - my mind is at rest now. I will buy a standard wing and let my bodyman know that he is going to have to spot weld the final inch on
cecotto479
It's not the final inch. It's about six inches, but it'll be immediately apparent when you look at two together where the difference is.
1981 E23 735i
Wilkie1
I am more than happy to buy a secondhand cab wing - I need the offside and it has the indicator in the wing (not sure if they all do or not). Anyone got one for sale? I am in Kent (Higham)
Rtaylor2208
pm cecotto479 he has a few.
George
Rather than starting a new thread...is there a difference between pre/post facelift front wings for the cabriolet?
Sold: 1986 E30 325i Cabriolet, Alpine White
Grrrmachine
- E30 Zone Wiki / Team Member
George
Brilliant, thanks
macas
How come almost everyone has the same avatar pic??
