i suspect the following could be the cause:
1) valve stem seals are the common cause for smokey startup but these were changed when i rebuilt the replacement head in january.
2) head gasket gone between an oilway and one cylinder (no oil in water / water in oil apparent so far)
3) a crack in the head in either one of the ports or the cumbustion chamber allowing oil to seep in there while stationary.
i'm totally stumped as to the case of this as the above ideas seem unlikely. any ideas? it was running fine (if a little spluttery when cold) before it flooded...
