im pondering buying another e30 for a runabout, maybe a cabby for summer fun
a cabby has popped up il know more details tomorrow, not sure where il find out tomorrow but "there are a couple of holes" in the hood
i know nothing about cabbys, so whats the deal with holes ? are there places minor holes are ok or are all holes bad holes, can they be repaired or is it a new hood job ? and if i were to go look, what sort of things/places do you check if its been leak damaged because of the holes
and what price is it to sort ? are breaker/used hoods readily available ? rough price ? and how much for new, although ideally i want something thats more or less a cae of just insure and put fuel in, than messing about with new hoods and a bit of a project car
cheers
cabby hoods
polsta
Rtaylor2208
Holes in the roof, will pretty much mean water in the cabin and potentially rust.
A good OEM 2nd hand roof is 300 to 400. There is a fella on here who does replacements for approx 500. Username is carhood something or other. Perished horseshoe seal, roof front rail seal are common as is failed hood motors on auto roofs and failed horshoe gas struts on the manual.
Budget £500 for a new hood.
Even small holes will leak water in, I would lift the carpet up and check the floor pans, they could be rusty if the carpet is wet/damp
cecotto479
- Caution Unreliable Seller
Hmmmm. Budget £500 for a ropey hood fitted or for a good hood to fit yourself.
This one is as good as I've seen l and was fitted last week at a cost of £775.
1981 E23 735i
