335i Lazur Blue Moredoor - Borbets on all Road Legal P12
Post Mon Apr 16, 2012 10:16 pm
Ah, need a good day to fiddle about to be honest, its all new to me this m30 mallarky
leeparkes
Post Mon Apr 16, 2012 11:38 pm
An M30 is basically a big M20, same management, similar valve train design etc... so faults are easy (ish) to trace.
Im getting low to mid 20 mpg with the B10 and it was probably about the same with the standard M30.
M30 V's 24v.:)
Ive had both running side by side for say the past 2 years, fair enough the 24v is in an E36 compact but it weighed in at 1260KG which pretty much E30 weight (my E30 weighed 1240kg while it was still M20)
IMO they are two totally different animals, 24v is smooth, light, refined and efficient and is a good engine (if looked after) but they need to be wound up before they get moving properly.
An M30 is a noisy old slugger, big cc with 2 valve head design, heavy, late 60's roots etc..But IMO they are more fun to drive on the road.
Power delivery on them is nuts, standard M30's make about 200 lb ft @ 1500-2k and you dont have to wait for the power to 'come on. It will pull out of a corner hard from 2k and rev right up to 6k with pretty much a constant wall of torque.
As for speed my totally standard M30 weighing 1309KG (car in sig) ran a 14.5 quarter mile at Santa pod 2 years ago, still had the massive 20KG dual mass fly fitted. 8O
Theo got similar times with his, iirc Zaust got 14.6 in his touring too.
if you are running it at York id aim for mid 14's.
Post Mon Apr 16, 2012 11:48 pm
Epic council activity Alex :D
love this pic :wink:
for fooks sake don't let mick behind the wheel of the M30 turd, being a 24v executive the torque curve could really scare him and cause irreversable damage to your seats :D
Post Tue Apr 17, 2012 4:38 pm
irreversible dammage to his tyres more like winkeye
that mid section is a two piece Alex.....
have you seen this to go with it ,cheap as fook 8)
http://www.ebay.co.uk/itm/BMW-3-E30-2-0 ... 23094e8e27
Rtaylor2208
Post Tue Apr 17, 2012 5:54 pm
Can't go wrong with that one above Alex bought one for my 325 last year and fits perfectly
Post Tue Apr 17, 2012 7:12 pm
Will get one mick cheers
looking forward to getting it on the road like
have you seen the cardboard number plate steve :D
Post Tue Apr 17, 2012 9:01 pm
Pics of Recaros ALex winkeye
Post Tue Apr 17, 2012 9:02 pm
They not in yet :D
Mick i left me wheel in your truck
Post Thu Apr 19, 2012 3:01 pm
Had a proper poke about in the engine today, and the wiring is far from my standard, plenty of block connectors, multi coloured wires and tape.
A few things ive noticed is that the cars fuel light is on and showing 3/4 full so something a miss there.
Rev counter doesnt work
The starter does not work from the ignition however of a switch, which i dont want.
First picture.
can someone identify whats going on here. it looks like part of the engine loom should all this be cut?
Inside the c101 plug thingy
On the starter there is a yellow and black wire cut and then another one attached, is this the council starter switch
there is also a green and black one that been cut
this is in the fuel injector wiring any idea
should all these wires be here?
the heater hoses havent even been connected.
where would these take the feed from
more mess
any idea what this connector is for and what the little hose with a screw in the end is suppose to be for
the engine runs rough at idle, when i remove the oil cap the idle doesnt drop which suggests there is an air leak somewhere however i want to sort all the messy wiring out before i start pulling the engine apart, some of the electrical connections really dont look like they will last very long and are allready falling apart
Allready started removing some councilness from the engine bay
Some Morsels for it
Post Thu Apr 19, 2012 3:21 pm
Sorry Alex, that is scrap. Alas, the latest in a long line :(
Post Thu Apr 19, 2012 3:33 pm
Definitely looks like an M30 neanderthal has been at that wiring!! Ditch it and start again.. 8O 8O
If only you'd started with a proper lump.. :)
Post Thu Apr 19, 2012 3:34 pm
Jhonno wrote:Definitely looks like an M30 neanderthal has been at that wiring!! Ditch it and start again.. 8O 8O
If only you'd started with a proper car :(
Fixed
leeparkes
Post Thu Apr 19, 2012 3:36 pm
That wiring is messy. :eek:
In your shoes id just get another loom rather than tackle that lot, cant understand why there are so many cut wires as an M30 will run plug & play you only need to cut two wires to get the rev counter working.
M20 looms work on these engines if its any help.
That hose with the screw in should attach to either the FPR or it plugs into the the smaller hose next to the large AFM to TB hose.
Small hose is part 13
Karan
Post Thu Apr 19, 2012 3:43 pm
It's amazing how people get even the simplest wiring cocked up,
Copper scrap ahoy
rob0r
Post Thu Apr 19, 2012 3:51 pm
Definitely get a new loom! The wiring was probably the easiest part of my 335i conversion.
goosiegander
Zonegoose
Post Thu Apr 19, 2012 4:02 pm
Fixed
Would that make me wrong for soiling a sock to the images of lazer blue 4 door correctness?
More pictures please!
Post Thu Apr 19, 2012 4:06 pm
are the looms pretty simple enough to change ?
so what do i need an m20 or m30 loom ? are all m30 ones the same ?
Post Thu Apr 19, 2012 4:23 pm
Karan wrote:It's amazing how people get even the simplest wiring cocked up,
Copper scrap ahoy
Well you'd have to question the IQ of the chap, given that he decided to drop an M30 in, in the first place.. :)
Post Thu Apr 19, 2012 4:58 pm
Haterz :D
Post Thu Apr 19, 2012 5:09 pm
should keep you busy for a while :D
Post Thu Apr 19, 2012 5:12 pm
It will do
Shame as i wanted it on the road but want it right first
leeparkes
Post Thu Apr 19, 2012 5:17 pm
You need an M30 loom, manual if possible but auto can be used if you swap the TPS plug. Make sure the loom you get is from around 88 to 92,later looms have a different C101 similar to M50's (which looks like what you have on now.)
M20 loom can be used but iirc some wires need lengthening.
Yes its fairly easy to swap over.
Btw the plug you mentioned earlier is nothing to worry about, im not sure but i think its for a lambda sensor which isnt really needed on these donks.
What number ECU do you have?
Post Thu Apr 19, 2012 5:18 pm
Not sure on ecu number
Ive put up a wanted advert see if anyone has anything
Post Thu Apr 19, 2012 7:19 pm
jesus Alex thats proper botchery :eek:
Hope you've got a soldering iron 8O
johnl320
Post Thu Apr 19, 2012 8:37 pm
Here is a shot of the wires needed to make the m30 run the ones cut and tucked behind my finger are mainly unused auto loom ones, your car won't be exactly the same, as mine is a chromie but it gives you an idea. If it was me I would be binning that loom and going for an m30/20 one.
On another note, if that is the state of the electrics I would seriously check the state of the home made engine mounts.
Post Thu Apr 19, 2012 10:21 pm
Ive seen the engine mounts and to be honest there pretty good :D
johnl320
Post Thu Apr 19, 2012 10:27 pm
sweet, just the electrickery they struggled with then
Post Thu Apr 19, 2012 10:49 pm
Pics of the mounts Alex?
leeparkes
Post Thu Apr 19, 2012 11:23 pm
Jhonno wrote:Pics of the mounts Alex?
+1
Post Fri Apr 20, 2012 6:24 pm
Will get some next time i'am out :)
i belive the last owner bought the engine allready with e30 mounts then wired it in :D
Not botherd about these issues to be honest as its still saved me doing an engine conversion that i would of never of got round to doing :D
Post Fri Apr 20, 2012 10:00 pm
Fook the haterz Alex, ill try to sort out a loom when i get back from Venice from the lads over on the irish forum, theres about 4 m30 breakers on there atm mo, if you cant get on by monday. :cool:
Post Fri Apr 20, 2012 10:04 pm
8) Cheers rav, The can moan all they like i dont care. might go to topless's on Sunday if the weather carries on and get a loom off him
Plan so far
new loom
Ive figured out how to connect heater hose
Fit 324d Washer bottle
e28 Airbox
4 pot wiring covers
m3 battery tray cover
Paint inlet and rocker cover silver.
DANTHE fan loom and possibly new fan
HT lead covers
and a bloody good clean/polish under the bonnet.
Hopefully should look "OEM" ish :D
Post Fri Apr 20, 2012 10:30 pm
will you ask mr topless if your going to see him for a front screen he has put by for me and i'll pay him no probs.
i'll pick the screen up when i drop your wheel off and i've got d'monds m52 fannymoulds to drop in to him on the scenic route .
so if you get the screen it will speed things up a knot winkeye
Post Fri Apr 20, 2012 10:31 pm
8) Will do see if i can be arsed saturday night :D
Post Fri Apr 20, 2012 10:37 pm
make sure it has a blau tint Alex winkeye
