The bracket that holds my a/c compressor to the block had a crack in it.
Here it is.
It has no numbers or id on it at all and frankly looks a bit home-made.
When I looked on the ETK, there seems to be one a/c bracket for all E30's and not only is it nothing like mine, it features bushed mountings and fixings that run downwards into the top of the compressor - mine has lugs for bolts to run horizontally through, so it seemed like I have the wrong compressor, and that in the absence of bushed mountings, the vibey old s14 had cracked the bracket, (and the adjuster bracket and slightly cracked the casting of the compressor).
I had the bracket welded as a short term fix and resolved to try and sort the problem going forward.
Then I found this picture on S14.net, which clearly shows the same bracket just next to the alternator.
http://i978.photobucket.com/albums/ae26 ... rts011.jpg
I'm now assuming that its p/n 82 39 9 404 494, which is listed on bmwfans / realoem, but not pictured, as a retrofit part for a re-manufactured a/c compressor for any E30. BTW, I sent the guys at BMW Cheltenham the pic of my bracket and they said they'd never seen it before.
My compressor has this p/n on it: 6452 8 363 550.9 and a BMW propellor logo - I'm assuming that it is the re-manufactured item.
What I really don't understand is why BMW apparently went from a fully bushed mounting to a hard mount. If I leave it as it is I can't help thinking its just going to shake itself to destruction.
I don't even use the a/c anyway, but seem a shame to bin it as it's part of the spec of a very original car.
Anyone got any ideas.
FEP
