door card clips
mcbonio
Post Fri Apr 13, 2012 10:31 pm
Does anyone know the part number (or even the correct name) for the little round white clips that hold the door card to the door itself?
Are these the fellas?
http://www.ebay.co.uk/itm/10x-BMW-Inter ... 1613wt_808
Thanks,
Mcbonio
kam-325i
Post Fri Apr 13, 2012 10:35 pm
1) 51 41 1 922 138 Clip lower part
2) 51 41 1 922 137 Clip Upper part
3) 51 41 1 870 718 Clamp
Image Door lining single parts - BMW parts catalog
Gavla
Post Sat Apr 14, 2012 10:37 am
Yes, those are the clips. The top part is designed so that you can "screw" it into the door card. Be aware that if your door card is a bit worse for wear then this piece will not stay in place on its own. I would buy originals.
