its a 316i lux with a 325i engine fitted to it! its a low spec model but i hope to change that in time!
thanks man! notting but the best equipment used around here lol!capri_rob wrote:Nice work - love the engine crane
+1 (Theres benefits to a farmyard I guess!)capri_rob wrote:Nice work - love the engine crane
A 325i sport gearbox has a dogleg gear pattern?? Do they?kam-325i wrote:There is no such thing as a 325 sport engine, they are all the same, but if the gearbox is a sport box, it will have a dogleg pattern gear change.
yeah i found out there is no difference between the engine's shortly after getting the engine. The gearbox is an ordinary 325i box but ill be changing it as one of the gearbox mounts is broke of! dont know weather to go for another normal or sport?kam-325i wrote:There is no such thing as a 325 sport engine, they are all the same, but if the gearbox is a sport box, it will have a dogleg pattern gear change.
thankssunnyr83 wrote:A 325i sport gearbox has a dogleg gear pattern?? Do they?kam-325i wrote:There is no such thing as a 325 sport engine, they are all the same, but if the gearbox is a sport box, it will have a dogleg pattern gear change.
Nice work by the way op.
i know the M3 had the dogleg box, but i have always thought that the sports box was dogleg also, along with the closer ratio's....madmax1410 wrote:i tought it was only m3 and some e21's that came with a dogleg box?kam-325i wrote:There is no such thing as a 325 sport engine, they are all the same, but if the gearbox is a sport box, it will have a dogleg pattern gear change.
No,the sports box has the same pattern gear change as a standerd 5 speed box but with closer ratios.kam-325i wrote:i know the M3 had the dogleg box, but i have always thought that the sports box was dogleg also, along with the closer ratio's....madmax1410 wrote:i tought it was only m3 and some e21's that came with a dogleg box?kam-325i wrote:There is no such thing as a 325 sport engine, they are all the same, but if the gearbox is a sport box, it will have a dogleg pattern gear change.
IIRC....some 323i had the optional "dogleg" sport box.macas wrote:No,the sports box has the same pattern gear change as a standerd 5 speed box but with closer ratios.kam-325i wrote:i know the M3 had the dogleg box, but i have always thought that the sports box was dogleg also, along with the closer ratio's....madmax1410 wrote: i tought it was only m3 and some e21's that came with a dogleg box?
yeah i read somewere that some e21's are fitted with dogleg box's but it may be just alpina one's?sunnyr83 wrote:Yes! The 325i sport gearbox is not a dogleg pattern. The m3 is but not sure on the e21.
Go for a 320i gearbox.
thanks i must check the box i have incase its a sport!csl wrote:IIRC....some 323i had the optional "dogleg" sport box.macas wrote:No,the sports box has the same pattern gear change as a standerd 5 speed box but with closer ratios.kam-325i wrote: i know the M3 had the dogleg box, but i have always thought that the sports box was dogleg also, along with the closer ratio's....
If you want a 325i sport box,look for the markings HJ/TNN on it.
Just checked up in "the bible"...written by Andyboy on here....and there was indeed a 323i dogleg sport box(Getrag 245).An ordinary 325i box will have NW,TNW or ANB on it.thanks i must check the box i have incase its a sport!
yeah i read it some where recently on here that some were fitted with dogleg's but its very rare apparently!csl wrote:Just checked up in "the bible"...written by Andyboy on here....and there was indeed a 323i dogleg sport box(Getrag 245).An ordinary 325i box will have NW,TNW or ANB on it.thanks i must check the box i have incase its a sport!
HTH.
Those check recaros are fantastic.
first up was replacing the exhaust gaskets and some fancy bosch wipers!
