How do I know if I have an LSD?
BEERBOY123
Post Sat Apr 07, 2012 5:43 pm
It's not on the build sheet for my iS but by chance bumped into the last owner but one the other day and after much misty eyed mumblings he said it had an LSD.
I didn't like to contradict him, he may be right. Any way of telling? (Without going drifting...).
Ta
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
adit
Post Sat Apr 07, 2012 5:48 pm
check the tag on the rear of the diff to see if it has an S before the ratio, e.g. S 3,64
[quote="bss325i"]
rich318i
Post Sat Apr 07, 2012 5:51 pm
if its off the ground u can check, hold one wheel and you if you can turn the other one its not a slipper if it is a slipper they both will want to move the same
cee
Post Sat Apr 07, 2012 6:28 pm
rich318i wrote:if its off the ground u can check, hold one wheel and you if you can turn the other one its not a slipper if it is a slipper they both will want to move the same
Make sure it's out of gear though
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
rich318i
Post Sat Apr 07, 2012 6:44 pm
would still if work in gear or not
cecotto479
Caution Unreliable Seller
Post Sat Apr 07, 2012 6:56 pm
If its jacked up, both wheels off the ground, out of gear, handbrake off; spin one wheel by hand.
With an open diff the wheels will counter rotate and with an LSD, both wheels will turn in the same direction.
1981 E23 735i
harry_p
Post Sat Apr 07, 2012 8:08 pm
No it won't. If it's in gear and you hold one wheel still, trying to turn the other will also be turning the gearbox and the engine.
Leaving it out of gear means you're just turning the diff and output side of the gearbox so it will turn quite easily.
cheers,
harry
adit
Post Sat Apr 07, 2012 8:09 pm
cecotto479 wrote:If its jacked up, both wheels off the ground, out of gear, handbrake off; spin one wheel by hand.
clear, concise and accurate information ^ ^ ^ , what a refereshing change :)
i remember this discussion/argument raging not so long ago, with all sorts of theories being banded about
[quote="bss325i"]
rich318i
Post Sat Apr 07, 2012 8:16 pm
harry_p wrote:
rich318i wrote:
cee wrote: Make sure it's out of gear though
yeah it still bring the same out come ? lsd or not
rich318i
Post Sat Apr 07, 2012 8:22 pm
best way to check 4000rpm and bang the clutch one black line or two then u will know easy
Post Sat Apr 07, 2012 8:25 pm
nail the turd from a standing start,
with a bit of luck you will have 2 black lines instead of a one tyre fire :D
sweep
Post Sat Apr 07, 2012 8:27 pm
It may of had a safety conversion?
redcar
Post Sat Apr 07, 2012 8:39 pm
Unfortunately these all apply to locked diffs as well.
Ideally, you would open the rear diff cover to check if the unit is an LSD.
cee
Post Sat Apr 07, 2012 8:41 pm
Causing wheelspin doesn't work. I quite often get two tyre lines even though I don't have an LSD. There are too many factors acting on it.
Easiest way is to do as above; lift and spin. Fin.
rich318i
Post Sat Apr 07, 2012 8:54 pm
adit
Post Sat Apr 07, 2012 8:55 pm
is it me, or is checking the tag far too simple :screwy:
[quote="bss325i"]
rich318i
Post Sat Apr 07, 2012 8:57 pm
drive it in the wet ffs lol soon find out if ur not used to a slipper
Post Sat Apr 07, 2012 8:58 pm
[quote="adit"]is it me, or is checking the tag far too simple :screwy:[/quote
Dropping the clutch at 4000rpm is more fun and easier :D
rich318i
Post Sat Apr 07, 2012 9:04 pm
Alex wrote:
adit wrote:is it me, or is checking the tag far too simple :screwy:[/quote
check it out
adit
Post Sat Apr 07, 2012 9:15 pm
[youtube][/youtube]
check it out
[quote="bss325i"]
BATTS91
Post Sat Apr 07, 2012 9:25 pm
that vid was cool lol
zaust
Zone day release
Post Sat Apr 07, 2012 9:40 pm
Way to simple mate. To many cooks and all that lol.
M30 Tech 1 Touring on gas.
rich318i
Post Sat Apr 07, 2012 9:47 pm
u know that m8 but what the diff dont have a TAG?
Post Sat Apr 07, 2012 11:12 pm
Look at all you lot, Beerboys asked another Dumb question, and sat back, while you lot argue onver the answer. :roll:
Every fooking weekend :roll:
Post Sat Apr 07, 2012 11:17 pm
Or what if some scammer has put an LSD tag on an open or welder?
Or what if someone has converted an open diff into an LSD?
Post Sat Apr 07, 2012 11:19 pm
cee wrote:Causing wheelspin doesn't work. I quite often get two tyre lines even though I don't have an LSD.
Nankangs?
there's no way a baby M3 will spin up both without an LSD unless it's on slippery ground !!
rich318i
Post Sat Apr 07, 2012 11:22 pm
LSD is just the locking clucth m8 i thought or can u inlight?
rich318i
Post Sat Apr 07, 2012 11:31 pm
Nankangs?
no open diff will spin both wheels
snakebrain
Post Sun Apr 08, 2012 2:28 am
e30topless wrote:nail the turd from a standing start,
It's an iS. He'll need a LOT of luck to get any wheelspin...... winkeye winkeye
snakebrain
Post Sun Apr 08, 2012 2:29 am
Nankangs?
Shite - didn't see that before I posted mine. :(
gooner1
Out humping Reindeer
Post Sun Apr 08, 2012 6:13 am
Ask Park Lane Classics. :)
Post Sun Apr 08, 2012 6:16 am
let me check it.
trippy diff checks are a speciality :D
rix313
Post Sun Apr 08, 2012 8:36 am
I'd put money on said owner being a bit of a simpleton and like most people, just says it has an LSD because thats what they 'eard down pub.
adit
Post Sun Apr 08, 2012 9:40 am
rich318i wrote:LSD is just the locking clucth m8 i thought or can u inlight?
Pardon? :?
http://www.e30zone.net/modules.php?name ... hlight=lsd
etc.etc....
[quote="bss325i"]
zaust
Zone day release
Post Sun Apr 08, 2012 10:58 am
Try all ways listed and report back with the results.
