calliper carrier bolt rounded on the rear!
e30-EVN
Post Sat Apr 07, 2012 2:20 pm
Rear caliper carrier bolt (17mm) has rounded off and I cannot budge it. I've tried shocking it, smashing a smaller socket on, all sorts but I cannot get it off.!
Any ideas boys?
What about welding a nut or socket to it?
I obv need this off before the rear disk will come off
Tia
Post Sat Apr 07, 2012 2:55 pm
Yes, MIG-welding a bolt or nut onto it usually works wonders.
Otherwise, a good soaking in PlusGas penetrating fluid (far better than WD40) then heating with a blowlamp may work.
If you have the room, you could drill a hole through it and insert a rod to turn it.
Or there's Easy Outs, which screw in with a reverse thread.
e30-EVN
Post Sat Apr 07, 2012 3:14 pm
My mate just bought me impact sockets and locking wheel nut removers....... The bolt is actually batered now :o: . You think this will work?
Failing that I will get my mate to weld a nut to the bugger!
Build and convert a car then get stuck on a bloody bolt :x :o:
Post Sat Apr 07, 2012 3:47 pm
Oh yes, there's always one stubborn or unobainable bolt having rebuilt the entire car! :roll:
Having presumably removed one caliper bolt, can you not gently prise the caliper up with a crowbar or similar then push it down again then lift again as required to loosen the stuck one?
Jim320i
E30 Zone News / COTM Team
Post Sat Apr 07, 2012 3:49 pm
Post Sat Apr 07, 2012 11:12 pm
Any joy with this?
Post Thu Apr 12, 2012 10:00 pm
Well? winkeye
bimanut
Post Thu Apr 12, 2012 10:16 pm
Weld a nut to it it`l get nice and warm spray a bit of stuff on it and should come out :)
Just seen the date thread posted :o:
Hope you got it off
